Polk LSI15 mod - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-29-2013, 06:06 PM - Thread Starter
peerguy's Avatar
I purchased a Polk LSI15 HT system based on responses on this forum. Thanks a ton!
I'm not happy with the Bass on the LSI15s. Its limited to 50hz at the bottom. I want to mod the LSI15s with woofers that can go down to 30 hz or eben 20 hz. and found these 4 Ohm 8" woofers from Polk. Please help me in choosing from the below or suggest anything else if you've done it.
1) Polk DB840:
Many people have used this successfully. This is my fallback option if nothing else works. $45.45 each on Amazon.
Frequency response: 30-200 Hz
Power Handling: Continuous 180 watts; Peak 360 watts
2) Polk DB840DVC:
I haven't seen this option on the forums yet. $53 each on Amazon. Will this work?
3) Polk AA3085-A MM840 DVC.
Again I haven't seen anyone do this mod. Will this work? $99 each on Amazon.
Frequency response: 26-200Hz.
Power Handling: Continuous 250 watts; Peak 500 watts
I'm tending towards the third option. Other 8" 4 ohm woofer suggestions are welcome. Thanks much for your help in the past and now in making my HT as good as I could imagine.
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
Surround: Polk LSI 7
AVR: Pioneer SC-1522
Amplifier: Parasound HCA 1200 ii
peerguy is offline
post #2 of 7 Old 08-29-2013, 11:32 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
50 hz? Where did you find that? Your own measurements? Polk's specs are -3dB at 32hz. As with most manufacturers Polk's specs are probably a bit "overstated", but not by that much.
skriefal is online now
post #3 of 7 Old 08-29-2013, 11:46 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
If you need more bass then add a sub. I wouldn't replace the woofer...
Mrkazador is offline
post #4 of 7 Old 08-30-2013, 02:48 AM
Cvetan1's Avatar
Quoted: 35 Post(s)
Liked: 50
^^Exactly. Cross those LSI's at 60 or 80hz and call it a day. I use to own LSi15's and they are fantastic speakers, but do have their limitations just like any other tower speaker.
Cvetan1 is offline
post #5 of 7 Old 08-30-2013, 07:02 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5201
Agreed! Better off buying a quality sub instead of trying to get deep bass out of tower speakers.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #6 of 7 Old 08-31-2013, 12:22 AM - Thread Starter
peerguy's Avatar
Thanks everyone. My second attempt to modify the LSI15s has been thwarted.
I'll get a quality SVS or Seaton Submersuve Sub to go with the HT system.
Cvetan1 likes this.
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #7 of 7 Old 10-18-2013, 07:00 AM - Thread Starter
peerguy's Avatar
Update: I purchased a PSA XV15 yesterday. Researched for 2 months and finally picked PSA xv15 from a pool of HSU, Rythmik, SVS, PSA, Outlaw, and Epik.
Price point, 15" driver, warranty, Tom's support on the forums and user reviews helped make the decision. I'm sure it'll be a good upgrade over the klipsch rw-12d.
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
Reply Speakers
Polk Audio Lsi15 Right Channel Tower Speaker Single Ebony , Polk Audio Lsi15 Left Channel Tower Speaker Single Ebony , Polk Audio Lsi15 Right Channel Tower Speaker Single Cherry , Polk Audio Lsi15 Left Channel Tower Speaker Single Cherry
