I'm considering using the Paradigm Studio 10 v5 for gaming...suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-01-2013, 09:32 AM - Thread Starter
Menorahman's Avatar
I was looking to buy the MilleniaOne CT system but just came across a pair of Studio 10's on Craigslist for $600. I don't know much about home audio, what would I need to get a good system going? Note: I'm not obsessed with bass.
Side question: The M1 CT has DSP processing to down mix DD 5.1, does that really make a big difference over PCM if it's just 2 speakers?
Menorahman is offline
post #2 of 7 Old 09-01-2013, 10:11 AM
Valtyr's Avatar
Liked: 80
They're okay... They can go very loud. They'd be fine for games but vocals leave a lot to be desired because they're not very forgiving. (At least in my experience with the Studio 20 V. 3's).
Valtyr is offline
post #3 of 7 Old 09-01-2013, 10:59 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I am sure that the Studio 10s would work fine. You would still probably want a sub. I would suggest something from SVS Audio or HSU Research.
I don't know for sure, but I wouldn't think so. What kind of receiver/amp will you be using with the speakers?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #4 of 7 Old 09-01-2013, 11:29 AM - Thread Starter
Menorahman's Avatar
The M1 CT comes with a sub / amp, if I got the Studio 10's I'm not sure what I would get with them.
post #5 of 7 Old 09-01-2013, 05:42 PM - Thread Starter
Menorahman's Avatar
Or maybe I'll just get the base Millenia CT, my room isn't exactly great for acoustics and I play / watch with my back up against a wall.
post #6 of 7 Old 09-01-2013, 07:12 PM
cel4145's Avatar
Liked: 2991
Well, you would definitely need to buy a receiver or amplifier to go with the Studio 10s.
post #7 of 7 Old 09-02-2013, 04:43 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
A simple low cost AVR would do the job - starting about $150
The Studio 10s are far more in the way of being speakers than that little portable setup. The woofers in the Studio 10s are larger than the subwoofer in the portable setup.
arnyk is offline
Reply Speakers
Paradigm Studio 60
