Powered center channel speaker - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2014, 11:47 AM
dtaudio's Avatar
Jakeabone,, that my friend would be the dream set-up with A8/A77x/A8 up front and HR824 on the sides.. have only heard the A7x but from what i've read and studied can't imagine that not sounding incredible!
dtaudio is offline
Old 01-20-2014, 12:27 PM
jakeabone's Avatar
Right now, I have my HR824s on the fireplace mantle. I will have to find some heavy duty floor stands also when I move them to the sides. I'll let you know what I find...
jakeabone is offline
Old 01-20-2014, 05:58 PM
dtaudio's Avatar
Thanks look forward to seeing what you find..
dtaudio is offline
Old 02-01-2014, 08:35 PM
hifibuyguy's Avatar
Quoted: 22 Post(s)
Originally Posted by jakeabone View Post
I am also configuring an active L//C/R system. I am leaning towards Adam speakers:
A8x / A77x / A8x - A8x has better low end and more power.
then I ran across a review in Soundandvision about Emotiva Steath 8 http://www.soundandvision.com/content/emotiva-pro-stealth-8-speaker-system. They had 3 of these for the front speakers. I don't have the height room for this so I was considering the A77x :
ES8 / A77x / ES8
Does anyone have any thoughts about the Emotiva speakers?
Eddy
I have a pair of the Stealth 8's. I'm setting up a new media/theater room in my basement and I'll be using the Stealth 8's for R & L main and Stealth 6's for side and rears. I also have a pair of Adam A3x that I may incorporate depending on if I can afford two pair of 6's. So far the Stealth 8 have far exceeded my expectations both sound and quality wise. Having owned many "high end" non powered speakers I will say the Stealth's rank up there with the best...from a fit and finish they could easily cost twice the price...and I'd put them up against the best monitors under $5000. I'm just waiting for Emotiva to put the Stealth 6's back on sale.
Emotiva XMC-1, Tekton Double impact, GoldenEar XXL center, Airmotiv 6's, GoldenEar Aeon 2's rear, Epik/DIY sub, Oppo DVD, Parts Express 15 sub kit, Epson 5030 projector, Crown XLS2500 X 4, 1 running the Tekton's
hifibuyguy is offline
Old 02-01-2014, 09:25 PM
jakeabone's Avatar
Great! I was hoping for good recommendation like yours! Do you have a center speaker? I'm hoping Emotiva will come out with the ES88 as was predicted... But I may just go ahead and get the A77x. It's a little pricy but from what I've heard, very good indeed....
Eddy
Old 02-01-2014, 09:32 PM
hifibuyguy's Avatar
Quoted: 22 Post(s)
I'm trying to wait for the Stealth 88...funny though I'm looking at reviews of the Adam A77x as we speak. I'm not finding any reviews of it being used as a center. Although they look like a typical center they actually are sold as a stereo pair of L and R speakers...the two mid/woofers are crossed over at different levels... so the "lower mid" is to be positioned on the outside of the stereo pair. In the mean time, I'll most likely try a phantom center...or hook up my older Infinity Beta 360 as a center until the 88's become available.
Old 02-01-2014, 09:35 PM
upNdown's Avatar
I don't mind saying that I don't understand anything that is happening here.
hifibuyguy likes this.
upNdown is offline
Old 02-03-2014, 11:10 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Where did you get lost? What post confused you?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
