What audio components for two theaters - $20,000 budget? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 09-05-2013, 02:33 PM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
Originally Posted by flyng_fool View Post
JTR Noesis:
From pg 211 of the JTR thread. Not official measurements, just what one AVS member measured using Omnimic.
That graph is not fine enough anyways.
I have owned the Klipsch subs and speakers in question. Their best attribute was sounding much bigger than they were and very cinema like. The subs can hold their own but you have to get them near cost because the FV15HP is better. The specs on the Klipsch subs are indoor specs. I say if the OP wants the cinema experience and size is not an issue go for the JBL pro 4722N's with 8530 surrounds. He can add dual OS's and he would have a system that would not only cost $11000 but kick some serious butt! The big problem is just that, this is a big system! To save even more money($3000) he can have someone build him dual GH's!
Marantz 7702 Atmos
MKtheater is online now
Old 09-05-2013, 03:54 PM
coytee's Avatar
Quoted: 161 Post(s)
Liked: 286
North Florida huh?
I've got some big horns by Klipsch, they are huge.  They will probably out-perform most of these other offerings.  They will not however, stay under your budget if you go full blown HT.
I'm in Jacksonville.  You're more than welcome to hear them to at least get a reference point to see if you want something stunning or something outrageous.
You could probably get one HT system in under your price point and it would be world class, don't think you could get both.
Honest offer if you're near or, want to take a casual drive on a weekend.
coytee is offline
Old 09-18-2013, 07:32 AM - Thread Starter
lwurn's Avatar
THANK YOU ALL for your feedback. I took advice from all of you; here's what I have done so far:
I ordered (and got a good deal from AVScience) and installed the Denon AVR4000 in my living room, which already has made a huge difference. Then I opened the grills of my 38 year-old huge box JBL L150 speakers and found all the foam/rubber gaskets around the speakers had disintegrated (embarrassing - guess I've been working too hard and didn't look - but I always knew the system needed help).
I had the gaskets replaced, then brought an old Klipsch Sub Woofer from the attic, so I now have powered two Klipsch Subs, and decent (if old) speakers comprising a 7.2 set-up (the side and rear speakers are also JBL's - but not quite as old). Then I did the Audessy tuning set-up with the Denon Receiver and WOW!! what a huge difference. OMG - it's like taking mufflers off our ears; my wife and I can hardly believe the differences!!
Next project is to upgrade the speakers in the Living Room, in anticipation of moving on, and building our big Theater Room in the pool cabana (described with a floor plan at the first post in this thread).
I did listen to a Klipsch Ultra 2 set-up and was surprised to be a bit underwhelmed with the sound, compared to what I was expecting. It was probably accurate sound, but did not sound as full of life as I expected - perhaps like the difference between guitarists' electronic amps and the old "full of life" tube amps we used long ago. Or maybe the stereo sales place that featured them just didn't turn them loud enough . . . .
Per recommendations on this forum, I am moving into testing other speakers. I started by ordering a set of HSU HB1MK2 bookshelf speakers and an HSU center, just to see what less expensive but wonderfully reviewed speakers will sound like, before taking the leap into spending $1,000's on speakers. Based on Forum responses, I will likely try the JTR speakers and certainly a JTR (or other) sub, as I continue my quest. Then, I will slowly work into adding some amps, I guess - or maybe I should do that first??? Thoughts people????
Will have to figure out how to add the additional amps . . . I do have receivers with additional wattage, but from what I read here, it appears that it's best to add dedicated amps. I am feeling old in my tech knowledge. Sorry I sold all my old MacIntosh Amps - I hear those are still considered good.
Thank you all again for your help. My mind is blown with the differences in sound already! Awesome forum, people!!
Larry
its phillip likes this.
lwurn is offline
Old 09-18-2013, 09:43 AM
NewHTbuyer's Avatar
Liked: 41
If you need to add amps, consider Emotiva. Very well reviewed and tested and reasonably priced.
NewHTbuyer is offline
Old 09-18-2013, 09:52 AM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
If you go with JTR speakers amps will not be necessary.
Emos 2nd Gen amps do offer great value to performance.
Chris
Chris
countryWV is offline
Old 09-18-2013, 11:31 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Originally Posted by MKtheater View Post
That graph is not fine enough anyways!
I'm not sure what you mean. I don't think he applied any smoothing to it.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 09-18-2013, 12:12 PM
Mike Garrett's Avatar
Quoted: 5591 Post(s)
Liked: 3578
Un-smoothed graphs, even with 10db vertical scale do not look that smooth.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 09-18-2013, 12:22 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
Chris
I think you mean Seaton speakers. Those are active speakers. Most JTR's are still passive. Many use Crown pro amps to drive at least the larger JTR's, which the OP many need given the size of his space.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Old 09-18-2013, 12:43 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
I was referring to the high sensitivity of the Noesis 212 @ 101dbs and the Noesis 228 @ 98dbs. The Denon X4000 will drive these speakers with enough power making an external amp unnecessary. I have a D-sonic M21500 driving my Triple 12s and although 1000 wpc @ 4ohm is not needed I want it. biggrin.gifwink.gif
Chris
Chris
Old 09-18-2013, 12:55 PM
Liked: 1767
Chris
I do still believe that with the fairly large room dimensions given by the OP, this will necessitate using more powerful amps with these larger speaker models, especially if they wish to play at movie-scale volumes. These receivers rarely output the specified rated wattage given their paltry power supplies. Good driver dampening specs. are helpful too.
Old 09-18-2013, 01:23 PM
carp's Avatar
Quoted: 2493 Post(s)
Liked: 1757
I can't even get my dual 12" drivers to move in my Noesis 212's and that's with using a receiver. I'm starting to think the 101 db rating is underrated, I thought for a long time that all other speakers I've calibrated were over rated but maybe it's the other way around. For example the 228's were 5 db's quieter when I calibrated them in my room to compare to the 212's (same result months apart on 2 different comparisons) and speakers from other manufacturers are so much lower than that compared to what they should be if the sensitivity ratings were correct.
Eventually I may get an amp to power them... just to do it because I like toys - but I sure as hell don't need it.
carp is offline
Old 09-18-2013, 01:24 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I went back and looked at it again. You're right. It is 1/12 smoothing.
Old 09-18-2013, 01:34 PM
countryWV's Avatar
Quoted: 405 Post(s)
Liked: 579
I am a straight up amp guy so I will never go against someone adding an external amp. My focus is Need vs Want. Speakers with 89dbs sensitivity Need an external amp to drive them to reference while 101dbs speakers Do Not. This has been an ongoing discussion over on the JTR thread for the past year and a half. If you are interested watch the Youtube video forum member Archaea posted of himself and a couple other members using a 25 wpc T-amp to drive the the Noesis 212HT to reference level with absoloutly no problems. I never give an AVR more than 80 wpc credit No matter their claims but if 25 wpc is enough then so would be the X4000. I only pointed this out to the OP to let him know that he can always add an amp later if he feels it is warranted.
My next receiver will be a PrePro like the Integra 80.3. This way there will be No Doubt that an external amp is Needed.smile.gif
Lots of great Info in the JTR speakers thread pertaining to the Need vs Want of an external amp vs AVR & JTR's HS/HE speaker designs.
2 cents
Chris
Chris
Old 09-18-2013, 04:12 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
Even with my clones powering my Noesis, the 12's still don't do much. It's not your reciever, I think it's just the way she goes...tongue.gif
N8DOGG is offline
Old 09-18-2013, 04:22 PM
carp's Avatar
Liked: 1757
Ha, to seem them move much you would probably have to put them outside and let the clones completely rip. Hmm... sounds like fun. smile.gif
carp is offline
Old 09-18-2013, 04:24 PM
carp's Avatar
Liked: 1757
The 228's on the other hand, you can really get those 8's moving. I think it just comes back to the fact that the 212's are such overkill that they aren't even breaking a sweat even at way above reference.
carp is offline
Old 09-19-2013, 09:55 AM
Genelec Man's Avatar
Quoted: 13 Post(s)
Take a look at QSC also. Their system designed for a "smaller" room would work great for your application.
http://qsccinema.com/solutions/small-room-solutions/
Genelec Man is offline
Old 09-25-2013, 03:15 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Originally Posted by lwurn View Post
Based on your rec's, I just ordered a Denon 4000 from AVS for the Living Room, to start. Do you suggest additional amplification beyond the Denon 4000 for the fronts, side and rear speakers?
First, I think you did a great job selecting your AVR. Denon, Onkyo, Integra, Anthem, etc are all great brands and have high quality power supplies and amplifiers in their flagship models. Additional amplification would be possible with that AVR since it has preamp outputs and the need would depend on what kind of speakers you get and how sensitive they are. There are many different sounding speakers so you will need to decide what kind you like – in my opinion (just my opinion, please don’t flame me) they can be grouped into three main categories:
Horn speakers with horn loaded compression drivers are usually “hot” in the high frequencies and are very sensitive / efficient – your AVR would almost certainly drive these to room filling / reference levels – look at Klipsch and JBL speakers. You either like these or you don’t – everyone loves how efficient they are but many (including me) find them to be very “fatiguing” even after a hour of listening – but that may be OK if you are only doing movie soundtracks.
Standard speakers / slightly bright speakers are less bright in the high frequency than horn speakers but are usually still fairly sensitive. These are the most common type of speakers and range from the low end bookshelf to the high end multi-driver towers and from mainstream to audiophile brands – Polk, Energy, Infinity, Definitive Technology, Paradigm, Focal – the prices climb from there.
Warm speakers are usually higher end “music only” and are out of my price range so I am definitely not the person to suggest brands. These tend to be less sensitive and would probably require external amplification especially if you want theater-like volume levels.
If I had that much to spend, I would make one room a reference room and spend 25%- 30% of the gear budget on some excellent speakers and put “good” speakers in the other room. Big floor standing towers can put out sound like you cannot believe and you could go from some modestly priced Polk towers to some outrageously powerful Paradigms. Spend at least as much on your center channel speaker as you do any other speaker – it is the primary speaker of your home theater and will be responsible for all dialog and much of the action.
http://www.polkaudio.com/products/rtia9
http://www.polkaudio.com/products/lsim704c
http://www.polkaudio.com/products/fxia6
http://paradigm.com/products/collection=reference/model=studio-100/page=overview
http://paradigm.com/products/collection=reference/model=studio-cc-690/page=overview
http://paradigm.com/products/collection=reference/model=studio-adp-590/page=overview
I will power the subs separately, I gather, right?
Most modern subs are powered subwoofers where the amplifier (and more importantly its frequency response) are tailored to the subwoofer driver / cabinet to give you much flatter response. For simplicity alone, I would suggest using powered subs. One previous suggestion that I saw that I totally agree with is the use of SVS SB13-Ultra subs. You just need to decide if you want ported subs (lower frequency, louder) or sealed subs (supposedly more accurate, tighter bass) – both would be excellent choices here – they even sell them in pairs at a discount. If you can afford more for one of the rooms, JL Audio and Paradigm make world class subwoofers.
http://www.svsound.com/dual-subwoofers/dual-pb12-plus#.UkM6AsZJOTM
http://www.svsound.com/dual-subwoofers/dual-sb13-ultra#.UkM6AcZJOTM
For electronics, I would suggest doing one room with your AVR and the other room (the one least likely to annoy your neighbors) with more powerful separates. Start with a preamp / surround processor (prepro) and add a big 7 channel amplifier. The best prepros have amazing performance but are are real budget killers which would easily swallow 25% - 50% of your budget (Anthem, Arcam, Bryston, etc). Look at the mid-fi brands like Integra, Onkyo, Marantz, Outlaw, etc. for great performance at much lower cost. The other plus here is if you ever have to upgrade the amp can be part of your new system. I really like the price / performance of Outlaw Audio amplifiers – they are made by ATI which is considered an “insider brand” as they are not very well known but used my many in the business – very beefy power supplies and amplifiers. The 7200 (or 7700 w/ balanced inputs) is a 90lb 7 x 200w beast of an amp and on sale this month.
http://outlawaudio.com/products/7200.html
http://outlawaudio.com/products/975.html
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
Aperion Verus Grand Tower Speaker Gloss Piano Black , Sony Str De995 B Av Receiver 5 1 Channel Black , Hsu Research Hb1 Mk2 , Denon Avr X4000 7 2 Channel Home Theater Receiver
