Best Soundbar... bar none! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 09-05-2013, 12:02 PM - Thread Starter
Michael James's Avatar
Quoted: 76 Post(s)
Because of the space (or lack thereof) between my front center and left speaker in-walls, I cannot use on-wall or stand alone speakers on the floor. The soundbar is pretty much the most I can use. 1 option is using a high end soundbar. I will be using 3 Sunfire Signature Amps to drive the Left, Center and Right portion of the soundbar plus the side and surround speakers. B&K Reference 70. All equipment will be in a Salamder type cabinet.
Who has had experiences with these?
- Revel
- BG Radia
- RBH
- Phase Technology
- Sonance
- Artison
- Leon
- Martin Logan
- Any others?
I am still planning on using in-wall side and possible rear surround speakers. I may or may not want to timbre match these surrounds.
Have not decided on subs but I may be able to get away with a stand alone sub or subs..possible conceal them..not sure.
Michael James
Cincinnati, Ohio
Michael James is offline
post #2 of 31 Old 09-05-2013, 12:58 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
- Revel
- BG Radia
- RBH
- Phase Technology
- Sonance
- Artison
- Leon
- Martin Logan
- Any others?
Also look at Kef
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #3 of 31 Old 09-05-2013, 01:12 PM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 116
There is a soundbar specific sub-forum if you're interested.
- Klipsch RF-82 ii, RC-62 ii, RS-52 ii
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
baloo_btru is offline
post #4 of 31 Old 09-05-2013, 01:26 PM
PlexMulti's Avatar
Liked: 46
I always felt that that forum was geared more towards active sound bars or complete 7.1 solutions. The OP is primarily asking about passive L/C/R sound bars that are in the relatively upper end of the spectrum, which I would consider to be applicable to the actual speaker forum. While these are "sound bars" I don't really view them the same way I do the HTIB pieces that are commonly discussed in that thread. I don't think that's fair to the manufacturers to lump them in with say, the Vizios, Samsungs, & ZVOX's of the world.
PlexMulti is offline
post #5 of 31 Old 09-05-2013, 03:45 PM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 116
Ok Thanks I didn't realize that. I don't have a problem with it I just thought he would get more help there.
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
post #6 of 31 Old 09-05-2013, 09:22 PM
Hookedonc4's Avatar
Quoted: 25 Post(s)
- Revel
- BG Radia
- RBH
- Phase Technology
- Sonance
- Artison
- Leon
- Martin Logan
- Any others?
Here you go I'm sure there is others. They can make you any length you need.
I hope you get it all worked out.
http://www.jamesloudspeaker.com/index.cfm?page=by_series&id=30
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #7 of 31 Old 09-06-2013, 06:05 AM - Thread Starter
Quoted: 76 Post(s)
Any recommendations? I have a ceiling that goes from 9 foot in the front of the room to 15 feet in back. What does dispersion look like? Is it good or bad to have high vertical dispersion? Are you mounting above or below the TV?
Michael James
Cincinnati, Ohio
post #8 of 31 Old 09-06-2013, 08:35 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
He probably would. Your suggestion was a good one. This is not the soundbar crowd in the speaker forum, and people here generally try to talk people out of buying a soundbar smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #9 of 31 Old 09-06-2013, 09:44 AM - Thread Starter
Quoted: 76 Post(s)
I'm looking at the $1500-3000 range. I will be providing my own power via 3 separate Sunfire Signature and Cinema amps. The other forum does look likes its geared for all in 1 solutions on the lower end.
Michael James
Cincinnati, Ohio
post #10 of 31 Old 09-06-2013, 10:28 AM
Collbug1's Avatar
What cel said that you should find a good speaker forum to find what you want? But i hear that there are so many experts on avsforum.biggrin.gif
Collbug1 is offline
post #11 of 31 Old 09-06-2013, 10:29 AM
Collbug1's Avatar
What cel said that you should find a good speaker forum to find what you want? But i hear that there are so many experts on avsforum.biggrin.gifWv7Zu
Collbug1 is offline
post #12 of 31 Old 09-06-2013, 10:32 AM
MusicFirst's Avatar
That is a pretty big room for any sound bar unfortunately... I'm guessing you will be disappointed with even "best"....
If you have too, I would look for the sound bar with highest sensitivity ratings and power handling, with the biggest drivers possible...
Then judge sound quality for yourself... Test in your current home etc. (preferably in a large room). Btw, how far is the listening position from the speakers?
Regards
MusicFirst is offline
post #13 of 31 Old 09-06-2013, 01:06 PM
dftkell's Avatar
Quoted: 74 Post(s)
Liked: 68
I would consider having a custom soundbar built. Rick Craig could design and build you a great one base on your specific needs. (If he's willing/able to take on the project.)
dftkell is offline
post #14 of 31 Old 09-06-2013, 01:10 PM
dftkell's Avatar
Quoted: 74 Post(s)
Liked: 68
Sel
selahaudio.com
dftkell is offline
post #15 of 31 Old 09-06-2013, 01:10 PM
Milt99's Avatar
Quoted: 230 Post(s)
Liked: 245
To the OP:
Check out the hometheater.com and audioholics.com They have some great reviews on Sound Bars in your price range
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is offline
post #16 of 31 Old 09-06-2013, 04:24 PM
Hookedonc4's Avatar
Quoted: 25 Post(s)
That looks like a good price range... How big is the TV?
Control4
post #17 of 31 Old 09-07-2013, 12:45 PM
MusicFirst's Avatar
I would say given your limited options for your big room consider:
Leon 616
Phase Technogy Teatro 3.0
Golden Ear Sound Bar (forget model)
Output will be limited regardless though....
post #18 of 31 Old 09-07-2013, 01:47 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
If you want them custom fit to match the width of your display, then there are only three, Triad, James and Leon.
ifor is offline
post #19 of 31 Old 09-08-2013, 11:56 PM
Kipa's Avatar
Quoted: 28 Post(s)
The Leon mentioned above, or also see the Atlantic Technology FS-5000.
Kipa
Kipa is offline
post #20 of 31 Old 09-09-2013, 07:26 AM - Thread Starter
Quoted: 76 Post(s)
Will be using a 65" plasma on an articulating mount. Omnimount makes one.
Seating position is 13 feet from the Plasma
Michael James
Cincinnati, Ohio
post #21 of 31 Old 09-09-2013, 07:36 AM - Thread Starter
Quoted: 76 Post(s)
I also heard BG Radia will also custom make one....
Michael James
Cincinnati, Ohio
post #22 of 31 Old 09-09-2013, 07:49 AM
PlexMulti's Avatar
Liked: 46
There are more and more companies climbing on board this concept....
Add,to your list
- BG Radia
- Induction Dynamics
- TruAudio (who has a little known custom division)
- I believe RBH will do this as well
Some manufacturers are going to start following Artison's example and make custom width grille fascias as well. This works as well as the other but gives a much lower cost to change the grille instead of the speaker as your display changes.
post #23 of 31 Old 09-09-2013, 10:42 AM
MusicFirst's Avatar
Add,to your list
- BG Radia
MultiPlex -
Do you know the specs on the BG Radia Sound Bar? I was at their site the other day and could not find it. Driver size, sensitivity, power handling, etc.
Though with the LP 13' away in that size room, I believe the OP might be a little "underwhelmed" regardless with which sound bar he chooses....
Pat
post #24 of 31 Old 09-09-2013, 10:53 AM
Mike Garrett's Avatar
Quoted: 5565 Post(s)
Liked: 3542
Originally Posted by MusicFirst View Post
MultiPlex -
Pat
I have listened to the Atlantic Technology Powerbar 235 at 10' and I was surprised at how good of a job that it did. Now this was in a nice enclosed rectangular room, so that helped. I would never consider it over a nice HT speaker system, if you have the space for correct speaker layout, but it did do a lot better than I expected.
mjgarrett100@gmail.com
Mike Garrett is online now
post #25 of 31 Old 09-09-2013, 11:39 AM
PlexMulti's Avatar
Liked: 46
The problem with a lot of companies sound bars, Atlantic's included, is that they do not go well with flat panels in what I would call a "typical" installation. To me, a sound bar mounted up under or above & against a flat panel display is perfect for an above the fireplace install. It keeps the TV low while aesthetically offering a very easy & unobtrusive look. A lot of companies product is too deep, too tall, or too challenging to mount and have look perfect.
Phase Technology's sound bar is another example of an unreal performer. It sounds HUGE and presents premium drivers and quality. But, it's got an equally HUGE draw back, IMO. It sticks out too far from the wall for a modern, super thin display and cannot bracket up with the TV. Instead, it is wall mounted underneath. It's just not attractive compared to other offerings (LEON, for example). The goal for most people is for their system is to SOUND & LOOK great. Too many options in 2013 for someone to only get one of the two.
Do these sound like dedicated theaters or big floor standing systems? Not usually. There are a few that can. I would argue that Phase Tech's and some of the larger LEON's do, but that negates the point of the sound bar. If space and aesthetics aren't a concern and 100% all out no-compromise performance is, then just throw towers or monitors around and live around your gear.
post #26 of 31 Old 09-09-2013, 12:03 PM
PlexMulti's Avatar
Liked: 46
MultiPlex -
Pat
Pat,
The BG sound bar is something that they make, but until they have their full lineup ready to release, don't expect to see it on their website yet. They are working on small, medium, and large configs and are going to have the line up and running as soon as they can. They are very talented over there.
Specs
- I don't want to speak for them, but I know that for a 60" panel they are going to be limited on width, so look for a driver compliment consisting of the NEO3 tweeters and the 4" Kevlar woofers (like what's found in the IC-201/
- For a 65" panel I think they may be able to get the NEO8 midrange in there as well and engineer it like the CC220 center (only without the 6 1/2" woofers). They are engineering one for our design center and I have somethings I want to run by them regarding drivers, layout, and costing.
In my opinion, I think that the NEO3 and the 4" drivers with some porting would present a clean sound that goes down far enough for a substantial sound. In dealing with BG for the last 7 years I would tell anyone this.... They don't make toys. They make serious gear. I don't think they'll engineer anything that isn't outstanding by their standards. That's just not what they do.
With the wide dispersion of the NEO3 the soundstage will be huge and, since they can handle high levels of power, there's no reason that 13' away from this is not going to sound strong enough.
Keep in mind, pieces like this are primarily used in a family room. Not a dedicated theater or media space where there is room for large in-walls or in-room box speaker. People's wants list typically go like this:
- Looks great without being obtrusive.
- Intelligible volume with spoken dialogue when watching TV or a movie.
- Play comfortably loud enough when having company over without becoming unpleasant.
- Excellent channel separation with a wide stage. Left sounds like the left, Center in the center, Right on the right.
- Loud and clean when turned up for action movies.
- Music Performance when streaming from iPOD, Rhapsody, SONOS, etc.
BG NEO3 along with the capable 4" Kevlar woofers will allow the sound bar to excel at all of this.
post #27 of 31 Old 09-11-2013, 09:41 AM
MusicFirst's Avatar
Multiplex,
Thanks for the response, and I agree. I used to be an installer/integrator myself with BG Radia as my main speaker line. In my theater room I have the 360's for my LCR's (all vertically placed with a transparent screen), SS-202's for my side surrounds, and the PD-8ci as rear surrounds.
Needless to say the sound is phenomenal...
post #28 of 31 Old 10-11-2013, 06:24 AM - Thread Starter
Quoted: 76 Post(s)
Does anyone have the Specs on the actual BG Radia Sound Bars?
Michael James
Cincinnati, Ohio
post #29 of 31 Old 10-11-2013, 09:09 AM
womenyiqi's Avatar
womenyiqi is offline
post #30 of 31 Old 10-11-2013, 03:42 PM
Hookedonc4's Avatar
Quoted: 25 Post(s)
All this talk got me motivated. My SPL39LCR will be here Monday for sitting room.
http://www.jamesloudspeaker.com/productdet.cfm?page=itemdetail&id=269
With this sub and M1000 amp added the sitting room will be rocking.
http://www.jamesloudspeaker.com/productdet.cfm?page=itemdetail&id=236
Control4
Reply Speakers
Revel Concerta F12 , Martin Logan Matinee Center Channel Electrostatic Speaker
