Speaker selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-05-2013, 06:33 PM - Thread Starter
ismean's Avatar
Hello,
I am putting together my first home theater and would like suggestions between the two speakers.
http://www.amazon.com/BIC-America-Venturi-Speaker-Single/dp/B00011KLOI/ref=cm_cr_pr_product_top for $127 each
or
http://www.amazon.com/Polk-Audio-TSi300-Floorstanding-Speaker/dp/B0018QPSBG/ref=sr_1_1?ie=UTF8&qid=1378427508&sr=8-1&keywords=tsi300 $200 for the pair.
Also plan to add a center channel and sub, looking for matching suggestions as well.
Any help would be much appreciated.
Pat
ismean is offline
post #2 of 15 Old 09-05-2013, 06:43 PM - Thread Starter
ismean's Avatar
Sorry I forgot to mention this is for movies and television only. I am not concerned with music if that makes a big difference.
Thanks again
ismean is offline
post #3 of 15 Old 09-05-2013, 06:47 PM
Kini62's Avatar
Quoted: 1414 Post(s)
Liked: 1297
Budget, room size, distance to main listening position, expectations??????
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #4 of 15 Old 09-05-2013, 07:05 PM - Thread Starter
ismean's Avatar
Budget for LRC sub and receiver i would like to be under $1000. Rear speakers can wait.
The room is 17' long 11' wide. I sit 12' from the TV. I would like a clean crisp movie experience with decent bass to add to effects. obviously as good as I can get within my budget being as limited as it is.
ismean is offline
post #5 of 15 Old 09-06-2013, 01:15 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
Hello Pat
I reckon this is about the best you can do for a grand:
If you want a good sounding budget floorstander, these are widely regarded to be the champion:
Pioneer by Andrew Jones SP-FS52
: $260/pair
Matching centre speaker: Pioneer by Andrew Jones SP-C22 : $100
Here is a review by Audioholics of the 5.1 Pioneer system.
The sub is fairly weak though. Substitute this solidly performing ID sub: SVS PB-1000 Outlet Special : $450
Good value 5.1 channel AVR with Audyssey MultEQ XT: Denon AVR-1713 (factory refurbished) : $270
TOTAL : $1080
I'm marginally over your desired budget, due to the step up to the SVS sub but I think it's worth it. If you get the Pio AJ monitors for surrounds later on, you'll have spent ~50% of your speaker budget on the sub, which is reasonable.
Kini62 likes this.
GIEGAR is offline
post #6 of 15 Old 09-06-2013, 09:20 AM - Thread Starter
ismean's Avatar
Thanks for the reply. I will definitely be picking up the pioneer floor and center speakers. For the sub i was thinking about
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1378480474&sr=1-1&keywords=bic+f12
I found the Denon 1713 on Amazon for slightly more but new.
Anyone have experience with Pioneer VSX-823-K?
ismean is offline
post #7 of 15 Old 09-06-2013, 03:43 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
I would go with the Denon for the better room correction software. Using the mic that comes with it, the Denon will automagically EQ your speakers AND sub for a better in-room response. The Pioneer will only correct the speakers.
The BIC F12 is one of the best subs for $200. But you said wanted decent bass. Subs are a big speaker in a big enclosure with an amplifier. So you are paying for a lot of stuff. Consequently, there are significant gains in getting a more expensive sub because $100 or $200 subs are a lot of compromise. This is why Audioholics recommends the SVS PB-1000 in their conclusion of their review of the Pioneer Andrew Jones speakers: http://www.audioholics.com/tower-speaker-reviews/pioneer-sp-pk52fs/pioneer-sp-pk52fs-conclusion. Now that's a $500 sub, but there are certainly options in between that and the BIC F12 that are worth the extra money.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #8 of 15 Old 09-06-2013, 03:59 PM
cel4145's Avatar
Liked: 2985
Originally Posted by GIEGAR View Post
Here is another good ID sub option: HSU Research VTF-1 MK2 (Labour Day Sale) : $429
That doesn't include shipping, does it? Add in shipping, and it's almost the same price as the PB-1000, which will have deeper extension (down to 19hz), and maybe even more output, based on the way people have been describing how loud it can get. S&V thought it was the best sub for under $500: http://www.soundandvisionmag.com/blog/2013/04/19/review-svs-pb-1000-subwoofer
cel4145 is offline
post #9 of 15 Old 09-06-2013, 06:10 PM - Thread Starter
ismean's Avatar
So i went in to demo some the pioneers and immediately realized my budget is unrealistic. I'm thinking i'm going to have to buy a few pieces at a time.
I was really impressed by the sound of the Definitive SM45 Monitors for $199 each. A friend of mine has an SVS sub and i love it. They didnt have one for me to hear tonight but the monitors were paired with a Martin Logan Dynamo 500. Im thinking i can get away with The Denon 2 fronts and a sub for now
ismean is offline
post #10 of 15 Old 09-08-2013, 09:11 AM
cel4145's Avatar
Liked: 2985
Makes sense to do that. I really like the Ascend Acoustics that GIEGAR mentioned. But if you found speakers you like the sound of, then go with them.
As far as the Martin Logan Dynamo 500, the SVS PB-1000 should be a better sub.
cel4145 is offline
post #11 of 15 Old 09-08-2013, 10:47 AM - Thread Starter
ismean's Avatar
Yes i was not impressed with the Pioneers and was amazed by the sound coming from the Def Tech's. Could be my lack of knowledge with home audio but i was happy so I ordered the SM45 pair, SVS PB1000, and the Denon AVR 1713 for $1200. My budget was more so to make the wife feel better so if i build in stages i can get away with spending a little more lol.
The center channel will come shortly then move the monitors to the back to make room for Floor standing speakers up front. Depending which floor speakers i get i assume the total system will cost about $3000.
I greatly appreciate everyone's advice on my first purchase. I will post back once everything is setup.
ismean is offline
post #12 of 15 Old 09-08-2013, 11:31 AM
cel4145's Avatar
Liked: 2985
That's a good plan. But consider you may not need floorstanders since you'll have the PB-1000. The sub will be taking over below 80hz, so the towers may not offer much improvement over larger monitors.
cel4145 is offline
post #13 of 15 Old 09-09-2013, 02:56 PM - Thread Starter
ismean's Avatar
Larger monitors makes things easier. Also is it a bad idea to mount book shelf speakers to the ceiling pointed downward? I've heard they need to be eye level to get the best sound.
ismean is offline
post #14 of 15 Old 09-09-2013, 04:02 PM
Bill Fitzmaurice's Avatar
Liked: 4631
It's a very good idea, assuming you mean 'close to the ceiling'.
Bill Fitzmaurice is online now
post #15 of 15 Old 09-09-2013, 07:50 PM
cel4145's Avatar
Liked: 2985
I suggest you now introduce yourself to the Def Tech owners thread and seek their opinion on the centre and mains that are within your budget and will be a good sonic match for the SM45's as surrounds. The SM65's would appear to be the obvious choice for a monitor style main speaker. The centre channel is not clear to me.
Edit: I see from the specs on the SM65 product page that it can be orientated vertically and horizontally, so three across the front is a viable option. I would still quiz the fellas on the Def Tech thread though. (Horizontally aligned MTM (D'Appolito) speakers do have issues with off-axis lobing.)
+1
Definitely get help from the owners thread. People there can tell you the best way to allocate your budget for building out your setup smile.gif
cel4145 is offline
Reply Speakers
Polk Audio Tsi300 Floorstanding Speaker Single Black , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Pioneer Andrew Jones Sp C22 Center Channel Speaker , Denon Avr 1713 Receiver , Pioneer Channel Av Receiver Vsx 823 K , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
