Yet Another Pioneer SP-FS52-LR Thread/Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-07-2013, 10:27 AM - Thread Starter
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
I have been using a pair of CSW Model Sixes forever as my fronts, with 17s as rears. They sound surprisingly good to my ear (not an audiophile, but I do home recording as a hobby, and have done a few demo recordings or friends, so my ears aren't completely useless). Their main flaw is I need to set the crossover to the sub at around 120Hz, which causes a bit of directionality to the low end. This is with the speakers flush to the wall (the corners are inaccessible, long story).
I see rave reviews on the SP-FS52-LRs, and I can go pick up pair for $89 each+tax right now should I so desire. I do not have money burning a hole in my pocket, so the question is: are these now discontinued towers a significant step up over the old bookshelf speakers?
ermghoti is offline
post #2 of 7 Old 09-07-2013, 08:00 PM
DaveCarrera4's Avatar
I have a pair and would suggest them.
Why go out to a movie theater?
DaveCarrera4 is offline
post #3 of 7 Old 09-08-2013, 11:21 AM - Thread Starter
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
Thank you! You wouldn't have any experience with the CSWs for comparison, would you?
ermghoti is offline
post #4 of 7 Old 09-09-2013, 03:31 AM - Thread Starter
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
I grabbed the FS52s, definitely a smoother transition from sub to mains bass handling, they don't seem to lose anything to the CSWs, except maybe I really haven't dialed in one setting that appeases the ear across numerous recordings and genre. Setting them to Large sounds ideal on some material, a bit crowded in the lows on others, with the inverse true with Small. Certainly a sound purchase (no pun intended).
ermghoti is offline
post #5 of 7 Old 12-18-2013, 03:45 PM
Wildcat_1's Avatar
Quoted: 13 Post(s)
Great thread, had a question as well. What should I set crossover for on my VSX 1121 to take into account the FS52's ? Also should I set the amp to 6 ohm (even though I have a mix of 6 and 8) or leave it at 8 when adding the FS52s ?
Wildcat_1 is offline
post #6 of 7 Old 12-18-2013, 05:47 PM - Thread Starter
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
They're rated at 6 ohms, so if your amp doesn't autoselect, use the 6 ohm setting. It's safe to run a higher impedance load than the amp expects, within reason, so a couple of 8 ohm speakers won't hurt anything, but they will be harder to drive to the same volume.
Start at 80Hz for the crossover, then fiddle. I go back and forth between 80 and 100Hz.
ermghoti is offline
post #7 of 7 Old 12-19-2013, 05:29 PM
Wildcat_1's Avatar
Quoted: 13 Post(s)
I have a Pio VSX 1121 so think I need to manually select speaker impedance. Looking forward to these speakers on it. Was a bit worried about going with 6 ohms but heard such great things about and from these speakers and got an AMAZING price that I thought it was worth a try
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker
