Neumann KH 310 vs Adam A77X as LCR for 5.1ch home theatre - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-08-2013, 07:49 AM - Thread Starter
ramkos's Avatar
Dear All Forum Members,
Comments please,
ramkos is offline
post #2 of 5 Old 09-08-2013, 04:04 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Neither choice. Consider speakers designed specifically for home theater.
What audio equipment do you already have to use with those speakers?
What's your budget for the rest of what you need?
How big is your room?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 5 Old 09-08-2013, 06:15 PM - Thread Starter
ramkos's Avatar
Room size is 25L*15W*10H.
I will be buying almost everything new. Budget for Audio is around $12000.
ramkos is offline
post #4 of 5 Old 09-08-2013, 06:17 PM - Thread Starter
ramkos's Avatar
I was initially looking for passive setup but after recommendation from my local AV installers and discussing with few forum members I am leaning towards active monitor setup. I still am confused whether active setup is good for home theatre or not.
ramkos is offline
post #5 of 5 Old 09-08-2013, 06:35 PM
cel4145's Avatar
Liked: 3001
If you start a thread stating something like "Need Dedicated HT Room Setup with $12000 Budget," then you'll find out what people on here will suggest. Instead, you've just been asking for advice on active setups, and the other thread I saw was not very active.
There are some members here who know about amazing passive setups. For example, these JTR Noesis 228HT: http://www.avsforum.com/t/1458711/jtr-noesis-228ht-the-best-speaker-you-never-heard-of-for-1200-pricepoint
Might want to give it a shot and see what people say. Look at how active this thread was with suggestions AND discussions over any of yours: http://www.avsforum.com/t/1485582/dedicated-home-theatre-for-budget-of-10-000-to-12-000-help-me-out-guys-i-need-some-ideas
Meanwhile, consider that local installers probably might not advise you any of those types of suggestions because they won't be able to sell you any product.
cel4145 is offline
Reply Speakers
Neumann Kh 310
