Whats better then Bose?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 09-08-2013, 08:19 AM - Thread Starter
DeathStalker57's Avatar
Hello,
I was wondering about a pair of book shelve speakers that are better sounding then Bose 301 and hopefully a bit cheaper. Maybe factory refurbished? I recently purchased an Onkyo TX-8050 receiver and im planing on purchasing a Polk PSW-505 for a sub woofer to compliment the speakers. Im using these in a small place. These speakers are going to be for music listening for some good rock and bass drops.
DeathStalker57 is offline
post #2 of 44 Old 09-08-2013, 08:25 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
Honestly? Just about anything is better than Bose. The PSW 505 isn't a bad sub, but the Klipsch RW12-D is one of the best values out there right now. You can find it on sale for as low as $250, you just have to patient.
What is your budget for the front speakers?
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 44 Old 09-08-2013, 08:47 AM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
Anything else will be better then any modern Bose "Blows" speaker. They haven't made good speakers in a very long time. It's been downhill since they started marketing their tiny micro sound systems. It's all garbage. There are many good bookshelf speaker options.
Secret Squirrel is offline
post #4 of 44 Old 09-08-2013, 08:56 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
The Wharfedale Diamond 10.1 speakers are some of the best you can get, and they are only $350 at Music Direct.
They sound one hell of a lot nicer than those Bose 301 turkeys.
Actually, the Pioneer BS22 speakers sound way better than those Bose speakers, and they list for under $200.
They are also some of the most attractive speakers you can buy; the wood finishes compare with some speakers costing thousands of dollars.
Check out the Stereophile review on them.
commsysman is offline
post #5 of 44 Old 09-08-2013, 08:58 AM - Thread Starter
i really did not want to spend alot on the front speakers i was considering a pair of Polk Audio TSi100 for $150.00 they seem good for a small room with the Polk Sub.
post #6 of 44 Old 09-08-2013, 09:08 AM
commsysman's Avatar
Liked: 567
The Pioneer BS22 are MUCH better than those Polks, and sometimes Amazon has them for under $150.
post #7 of 44 Old 09-08-2013, 09:26 AM - Thread Starter
im thinking of going with the Cambridge audio S20 instead unless there are any major problems with them from Crutchfield
post #8 of 44 Old 09-08-2013, 09:32 AM
Chevypower's Avatar
Liked: 40
I tried to find out the technical specs on Bose Lifestyles, which Bose does not publish, but this is what I found out:
Frequency response:
- Cubes: 280Hz-13.3Khz +/- 10.5 dB.
- Acoustimass module: 46Hz-200Hz.
So there you have it. No mid-range, no highs, no lows, it must be a Bose.
Chevypower is offline
post #9 of 44 Old 09-08-2013, 09:43 AM
Quoted: 44 Post(s)
Liked: 39
Those specifications back up my previous statement. Those specifications really Blow. Especially those speakers they call cubes. They're basically a tweeter and a bad one at that. And the bass module is about as good as a cereal box with a 4'' driver put in it. I think the cereal box would sound better and be more capable.
post #10 of 44 Old 09-08-2013, 10:25 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
Cambridge makes nice little speakers. A lot of people really like the Energy Take series.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269024&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Home+Audio+Speakers-_-N82E16882269024&gclid=CIbGnduovLkCFQFk7AodjQIAhw
The sub that comes with it should be plenty for your apartment
spddy101 likes this.
post #11 of 44 Old 09-08-2013, 10:26 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
Why would you wnt to insult a poor defenseless cereal box like that?
post #12 of 44 Old 09-08-2013, 11:02 AM
Quoted: 44 Post(s)
Liked: 39
I'm rooting for the cereal box. If I had to pick between the two I would pick the cereal box with the driver thrown inside. It would be lighter on my wallet and it would probably sound better then the Blows bass module.biggrin.gif
post #13 of 44 Old 09-08-2013, 01:18 PM
dannybenz's Avatar
Quoted: 13 Post(s)
THIS!
You have a nice receiver and sub. I think the Wharfedales should be the lowest quality you should look at. They are an amazing deal for that price.
Other than that there is the Infinity P163 for around $180 a pair, and the Energy as another member mentioned above.
dannybenz is offline
post #14 of 44 Old 09-08-2013, 01:22 PM
dannybenz's Avatar
Quoted: 13 Post(s)
Frequency response:
Bose does not publish specs for the cubes. Are those specs real measured third party or is that some joke, becuase that is pathetic. +/- 3db is prolly around 500hz-10khz lol. You will hear voices coming from the Acoustimass "module". haha
post #15 of 44 Old 09-08-2013, 01:24 PM - Thread Starter
Well listen money is kinda tight and a technical representative form Crutchfield recommended the S20 so im most likely going to do that. I think i can get some nice sounding music form my little setup for a small area that will sound fairly decent for most people.
post #16 of 44 Old 09-08-2013, 01:38 PM
dannybenz's Avatar
Quoted: 13 Post(s)
Do not take recommendations from Crutchfield. I took advice from them a couple months back for car speakers and they were horrible. Absolutely terrible sounding speakers. For your price range I think the Pioneers SP-BS22-LR would sound the best by far. There are people trying them with $2k in electronics with very good results.
post #17 of 44 Old 09-08-2013, 01:46 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
The specs are from Sound and Vision.
http://liquidtheater.com/editorial_56.html
bladerunner6 is offline
post #18 of 44 Old 09-08-2013, 02:27 PM
afrogt's Avatar
Quoted: 1369 Post(s)
Liked: 948
He's safe with this recommendation. The S30's are very good speakers and better than the BS22 although the Pioneer is significantly cheaper. There's a pretty large thread about them here on AVS so one wouldn't really need the opinion of Crutchfield sales so make the purchase.
Afro GT
afrogt is online now
post #19 of 44 Old 09-08-2013, 03:48 PM
Chevypower's Avatar
Liked: 40
And still not be low enough to replicate James Earl Jones or Sam Elliott! lol.
post #20 of 44 Old 09-08-2013, 04:26 PM - Thread Starter
Well it seems like i have heard no negative views for the S20's so i shall go ahead and purchase them. Hopefully now i shall be able to out perform my neighbor with the Bose 301's.
post #21 of 44 Old 09-08-2013, 04:27 PM
jerrymb's Avatar
Why not get the S30's?
jerrymb is offline
post #22 of 44 Old 09-08-2013, 04:28 PM - Thread Starter
the S30's are a bit out of my price range at the moment the 150$ is really firm.
post #23 of 44 Old 09-08-2013, 04:30 PM
jerrymb's Avatar
Because AVHIFI has the 30's for $197 free shipping. I'm about to order a pair.
jerrymb is offline
post #24 of 44 Old 09-08-2013, 04:38 PM - Thread Starter
I would like the S30's if they were about 150$ but they are not so i shall be sticking with the S20's i hear the S30's have better bass but i have a sub for that.
jerrymb likes this.
post #25 of 44 Old 09-08-2013, 07:35 PM
_Michaelangelo_'s Avatar
Quoted: 52 Post(s)
Liked: 65
Why would you want to insult a poor defenseless cereal box like that?
LOL. Nice one!
"Know Thyself" - The Beginning of ALL Wisdom
I've shipped games on DS, PC, PS1, PS2, Wii, and helped numerous companies with PS3 game dev support. Ask me anything about game programming, game design, graphics, or color.
_Michaelangelo_ is offline
post #26 of 44 Old 09-08-2013, 07:52 PM
Bond 007's Avatar
Quoted: 2596 Post(s)
Liked: 2061
I thought someone was joking when I saw the title of this thread.
Licence to Kill
Bond 007 is offline
post #27 of 44 Old 09-09-2013, 08:31 AM
thestumper's Avatar
I have the TSi 100's set up as surrounds at the moment. They work well in that role. I have TSi 400's currently as mains. These are NOT audiophile grade speakers IMO, but they do a nice job with home theater dynamics. I have an old, smaller Paradigm sub, and am working on getting that upgraded - for HT that is perhaps the most critical part of the speaker "chain".
Basically, I think the Polks are OK for home theater, but for music, I would really consider another direction (and not Bose...). Those S20's should be a good value for you and perform well.
thestumper is offline
post #28 of 44 Old 09-10-2013, 07:57 AM - Thread Starter
So I purchased the Polk sub and the Cambridge audio S20 speakers thanks guys
post #29 of 44 Old 09-10-2013, 08:36 AM
Bond 007's Avatar
Liked: 2061
How much did you pay for the 505?
Licence to Kill
Bond 007 is offline
post #30 of 44 Old 09-10-2013, 10:38 AM - Thread Starter
I purchased it on Amazon but since i had a gift card i only ended up paying about $60 for the sub out of pocket. It was around $220.00 on Amazon
Reply Speakers
Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Klipsch Rw 12d 12 Subwoofer Each , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Polk Audio Tsi100 Bookshelf Speakers Pair Cherry
