Speakers for house/ garage party - AVS Forum | Home Theater Discussions And Reviews
Old 09-09-2013, 03:54 PM - Thread Starter
mr lehee's Avatar
Hi there ! Looking at buying speakers for the garage/ house for parties. I have a 2000 dollar cap. Right now I have cerwin vega d7 model speakers a pioneer vex-21 reciever and a jbl nl-150 sub.. Looking at upgrading to a better set . Main use for system would be for loud music with a dj . Any help would be appreciated
mr lehee is offline
Old 09-09-2013, 06:26 PM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
You should be looking at active PA speakers, how big of a space is it?
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 09-09-2013, 08:27 PM - Thread Starter
mr lehee's Avatar
1000 square feet approx
mr lehee is offline
Old 09-10-2013, 05:58 AM
Liked: 1319
I would go take a look at guitar center and listen to some speakers. You aren't going to get great clarity, but you will get some serious SPL.
Another option is DIY. If you are somewhat handy you could buy some speaker kits from diysoundgroup and get a lot of bang for your buck. But then you also need amplification and subs. I think PA speakers are the simplest option in terms of transporting and setting up.
Old 09-10-2013, 08:27 AM
tanveers's Avatar
JBL speakers are a great choice for live venues. Look into some QSC's Monitors. I think they would be an ideal match for your space. The QSC k152's have plenty of power to deliver pounding SPL levels at 1000 watts. Before you go make a large purchase like that, you should look into renting some monitors out to see which monitors suit your needs. Checkout the QSC's and a few other JBL's here: http://aarental.com/product/qsc-k152-speaker-rental/ http://aarental.com/speaker-rental/
Let me know if that helps.
Ben
Lead AV Tech,AA Rental
tanveers is offline
