Can I use 2 rca splitters to connect Xbox and PC to amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-09-2013, 05:02 PM - Thread Starter
gtrplyr201's Avatar
Right now I have a Lepai 2020a+ amp for my PC audio setup and as you can see it only has room for 1 audio input. Could I use 2 of these to input both my Xbox rca's and the PC rca's and get sound out of both of them at the same time? I'm wondering this because I like to listen to music while I play Xbox but I also would like to hear the game audio too. Thanks!
gtrplyr201 is offline
post #2 of 4 Old 09-09-2013, 06:02 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
The Lepai actually has two inputs. I know I own two of them. One input has dual rca and the other is a 3.5mm stereo jack.
Just buy a dual rca to 3.5mm cable and you can use both inputs. Should cost about $3.
Afro GT
afrogt is offline
post #3 of 4 Old 09-09-2013, 08:50 PM - Thread Starter
gtrplyr201's Avatar
So if I'm understanding you correctly I can use one of these or something plugged into the "MP3" input for my Xbox and keep using the original RCA's for my computer? Would using that adapter be stereo sound?
post #4 of 4 Old 09-09-2013, 09:17 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
There might not be room on the back of the Lepai for that plug and to plug in RCA cables beside it (don't remember), but yes. You are right in principle. If that's a little too big, then a cable with that kind of conversion from 3.5mm to RCA would work.smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
