Picked up some NHT 1.1s at a garage sale... I don't know anything about them and would appreciate any help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-10-2013, 12:57 AM - Thread Starter
Douglas_d's Avatar
I stopped off a garage sale on Saturday and picked up 3 NHT 1.1 speakers for $10 (2x 1.1 L and R matching pair and a 1.1c). These are dated 1994, so they apparently have some years on them. I checked the foam around each woofer and they appear to be in good shape. I just finished setting up my home theater room (minus the audio system) and was thinking about maybe getting these guys setup as the fronts?
Basically, any information about these would be awesome, also, since I'm here, I might as well start asking about what I could pair with these for my theater setup. 17x20' room, looking to do 7.2 (eventually), and I currently only have my old computer Logitech Z-5500s setup in the room until I start procuring speakers and a receiver.
Douglas_d is offline
post #2 of 6 Old 09-10-2013, 02:38 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2900
Very nice and detailed sounding speakers. I used to have their predecessors (Model 1 and 1c).
3 identical speakers across the front will give you a seamless front soundstage that will sound consistent as sounds pan from left to right. Excellent start to a 7.2-speaker set-up!
I would scan the used market (eBay, AudioGon) for more 1.1 or 1.1c speakers to use as surrounds, to continue the consistent sound all the way around. Should sound awesome by the time you're done.
Sanjay
sdurani is offline
post #3 of 6 Old 09-10-2013, 09:22 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Might even find once you get a receiver that it sounds better than the Logitechs even without the surrounds.
Although that's not critical. While it's important for the front soundstage to timbre match, not so important for the surrounds to match the front. I probably wouldn't worry about it given how hard it might be to find four more.
After the receiver, I would also probably go with the a sub next over the surrounds. That will give you a fuller sound for HT usage.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 6 Old 09-10-2013, 09:54 AM
sdurani's Avatar
Liked: 2900
I posted my comment after finding at least five more on sale on eBay.
Sanjay
sdurani is offline
post #5 of 6 Old 09-10-2013, 10:15 AM
65 Electra Glide's Avatar
Quoted: 78 Post(s)
Liked: 50
These were dedicated Left/Right speakers, so I wouldn't use a third one as a vertical center speaker though because of the Focused Image Geometry front baffle. That would create a big suck-out on one side of the other.
65 Electra Glide is offline
post #6 of 6 Old 09-10-2013, 12:47 PM
sdurani's Avatar
Liked: 2900
The third one, as the OP mentioned in the first post, was the centre channel version of the speaker, which doesn't have an angled baffle.
Sanjay
sdurani is offline
Reply Speakers
