Old Paradigm studio v2 setup plus a sub or new equivalent $1800 range with sub later. - AVS Forum | Home Theater Discussions And Reviews
Old 09-10-2013, 08:26 PM - Thread Starter
scjb007's Avatar
My goal is to assemble a solid HT setup. I have an option to buy Paradigm Studio 60 v2, studio cc v2, and adp v2 for $750. I know other members have this setup, but what would you do? Would you go newer if upper end of the budget was $1800 for front and center? Or older and leave room for a sub?
My living room is 18 x 30 and my existing equipment includes denon avr-1908 and definitive technology procinema 600.
Thanks in advance for your advice,
Jeremy
scjb007 is offline
Old 09-11-2013, 05:43 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Jeremy
I would definitely go for the Paradigms and then buy a nice sub. With upwards of $1000, you have a lot of options and can get a great sub that will be a night and day improvement from your current system. Speakers last a long time when taken care of, so you shouldn't be all that concerned buying used.
Take a look at Rythmik, SVS, HSU, and Outlaw for subs. You have a big space, so you are going to need to invest a lot to get appropriate bass in that room. I would probably consider a pair of ported subs, a pair of SVS PB-1000 would be a good addition to the Paradigms.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 09-11-2013, 05:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The Procinema system's weak spot is probably the dual 8" subwoofer although the 3" midranges in the statelites have their problems, too.
The Paradigm upgrade would be substantial, new sub or not. The Procinema sub is not all that impressive, but you should at least try it with the new speakers, Even though its 2 each 8" woofers are only 1" larger than the one in the Studio 60.
arnyk is offline
Paradigm Studio 60 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
