Klipsch Reference Bookshelf vs. Klipsch Reference Surround - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-11-2013, 08:19 AM - Thread Starter
jeff1967's Avatar
Quoted: 35 Post(s)
Liked: 448
I need opinions on the following:
Considering the Klipsch Reference RS41 bookshelf and surround speakers as an upgrade to my 5.1 system.
Thinking of the bookshelfs for fronts and the surrounds for the sides.
Here is my question:
Is there any signifigant downside to just using the surrounds all around instead of bookshelfs for the fronts? They have the same specs as far as power and sensitivity and are the same price. I like the look of the surrounds better. The bookshelfs have a port on the rear and since they will be wall mounted I am wondering how that may effect sound (although they have keyholes on the back so I think Klipsch would say its ok).
http://www.klipsch.com/rb-41-ii-bookshelf-speakers-pair/details
http://www.klipsch.com/rs-41-ii-surround-speaker/details#specs
I am considering other brands as well, but would like to keep this discussion limited to these 2 speakers. smile.gif
Panasonic TC-P55ST50 Plasma 55"
Oppo BDP-203 Blu Ray, Toshiba A30 HD DVD
Onkyo RZ-900 Receiver (7.1 Config)
Klipsch R28F, RC500, RS400, RB600, SW10 Sub
Cisco Explorer 8642HDC HD DVR
Mac Mini/PS3/Wii, Harmony Smart Control
jeff1967 is offline
post #2 of 4 Old 09-11-2013, 08:54 AM
Zen Traveler's Avatar
Quoted: 579 Post(s)
Liked: 587
Originally Posted by jeff1967 View Post
IHere is my question:
You do not want to use the RS-41 as Front speakers because of their design to disperse sound instead of it coming straight towards you which is what you want in your Front soundstage.
Zen Traveler is offline
post #3 of 4 Old 09-11-2013, 10:40 AM - Thread Starter
jeff1967's Avatar
Quoted: 35 Post(s)
Liked: 448
Yes, that was a concern also. Still wondering about blocking the port on the back of the bookshelfs though.
jeff1967 is offline
post #4 of 4 Old 09-11-2013, 10:50 AM
Quoted: 579 Post(s)
Liked: 587
You definitely wouldn't want to do that and need some space behind it..That said, you could step up the RB-61 which is front ported: http://www.klipsch.com/rb-61-ii-bookshelf-speakers-pair
Regardless, you don't want to use the RS line as Front speakers.
Reply Speakers
Klipsch Rs 41 Ii Reference Series Wide Dispersion Surround Speaker Black Each
