Need help with speakers and subs..PLEASE! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-15-2013, 05:56 AM - Thread Starter
shadillac's Avatar
Hello as I am new to this board.. This is actually my first post!!
I just bought a new YamahaRX-675 receiver adn the new Vizio 70inch tv and i'm looking to add speakers now. I would like your input please as Im on a budget.
Im looking to get maybe Polk Audio TSX-440T's and matching center channel, but have read great things about BIC America Accoustic tech series and Flaunce XL7F speakers. (what do you guys think)
I also have the Subs narrowed down to Cadence CSX 12, Bic F-12 or NXG BAS 500. I will be needing 2 subs also. I have been reading Jim Wilson reviews on subs and have been talking to ED Frias from EFE speakers/technology. Just trying to get the best that I can afford.
My room is 30x16 and 8ft tall and I will mainly use this for HT and just a little bit of music.
Any help would be great!!
Thanks in advance
Shadillac.
shadillac is offline
post #2 of 6 Old 09-15-2013, 10:28 AM
cel4145's Avatar
Quoted: 2659 Post(s)
Liked: 2991
For mainly HT usage, towers don't add a lot of advantage over monitor sized speakers since you will be using a sub which could be crossed over at 80hz. Often a better version monitor can give better quality sound. A great compromise in between would be the Ascend Acoustics CMT-340 SE mini towers. Dual 6.5" drivers smile.gif
That's a big, big room, and the subs you are considering may be underwhelming in that size space.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 6 Old 09-15-2013, 10:59 AM - Thread Starter
shadillac's Avatar
I was kinda worried about the size of the room.
What if I ran the Cadence 15" 600w sub instead of 2 12"s. Would that help out any at all?
I have also been considering Polk RTi10's...
post #4 of 6 Old 09-15-2013, 11:22 AM
cel4145's Avatar
Liked: 2991
The Premier Acoustics PA-150 measures better than the 15" Cadence. It can typically be had for $350 from Acoustic Sound Design if you make them an offer. I would go for that in your size room unless you are willing to spend a lot more.
cel4145 is offline
post #5 of 6 Old 09-15-2013, 11:24 AM
cel4145's Avatar
Liked: 2991
See data-bass.com in the systems section for links to more measurements for both subs.
cel4145 is offline
post #6 of 6 Old 09-15-2013, 05:51 PM - Thread Starter
shadillac's Avatar
Thanks for the info.. Im gonna check into it now!
Reply Speakers
