Speaker Damage from Recordings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-15-2013, 06:55 PM - Thread Starter
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Is it possible to damage a speaker or tweeter from a crack or hiss in a recording? I watch a lot of sports and often times after a big play, the crowd noise causes an audio spike and sounds nasty coming through the speakers - highly distorted.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Samsung PN64F8500 (Master Bedroom)
Tom Riddle is offline
post #2 of 9 Old 09-15-2013, 06:56 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
you'd have to have the volume up really loud for that to happen.
I'm not quite sure what watching sports on TV has to do with a recording though.
Afro GT
afrogt is offline
post #3 of 9 Old 09-15-2013, 07:20 PM - Thread Starter
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Just referring to the fact that it is a recorded sound distortion. Thanks for the reply.
PSA V3600I
Emotiva XPA-5
post #4 of 9 Old 09-15-2013, 07:54 PM
Bill Fitzmaurice's Avatar
Liked: 4639
Almost all electric lead guitar tones are distorted, and all synthesizers are heavily distorted. It's not a problem.
Bill Fitzmaurice is online now
post #5 of 9 Old 09-16-2013, 07:02 AM - Thread Starter
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Thanks Bill and afrogt for the replies.
PSA V3600I
Emotiva XPA-5
post #6 of 9 Old 09-16-2013, 09:48 AM
Liked: 4639
Looking at this again, there is a potential danger here. If the distortion is sourced at the broadcasting end then there's little danger. However, if the source of the distortion is your system, either in the amp clipping when it can't cleanly amplify the signal or the speakers clipping when they can't handle the amp output, or both, then your tweeters could be at risk.
My system has plenty of headroom all around, and I never notice crowd noise sourced distortion. If you hear that distortion regularly with a particular event see if it goes away if you turn the volume down. If it does then the distortion is coming from your system, so either the amp or speakers or both are undersized for the volume you're listening at. If the distortion is still present at low volume then the broadcast is the source and you should be OK.
post #7 of 9 Old 09-16-2013, 12:12 PM - Thread Starter
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Thanks Bill. I checked yesterday and it was definitely the source. I've never run into any true clipping situations with my amp (onkyo tx-nr808) and I have the Klipsch RF-62 II system which is very efficient. It only happens on certain broadcasts where it goes from extremely quiet to loud all at once and I'm guessing tests the mics being used. I switched it over to the television speakers and it happened there too at lower volumes. Football typically isn't an offender, usually golf.
PSA V3600I
Emotiva XPA-5
post #8 of 9 Old 09-16-2013, 03:26 PM
Liked: 4639
That's not necessarily distortion per se, it's often comb filtering, caused by having multiple mics at different positions around the course. And of course the obligatory idiot yelling "In the hole!" when someone hits a drive that couldn't possibly reach the green by 200 yards. mad.gif
post #9 of 9 Old 09-16-2013, 06:10 PM - Thread Starter
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Lol, that and any other phrase from Happy Gilmore. I've never heard of comb filtering before - just did some reading on it and sounds interesting. I do know it sounds particularly nasty coming through my speakers.
PSA V3600I
Emotiva XPA-5
Reply Speakers
