Ascend Sierra-1 / 170s: Worth it in my setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-15-2013, 11:53 PM - Thread Starter
dnadrifter's Avatar
I currently have a Denon 891/2311 receiver in a 3.1 setup running PSB T45s and a matching center (C5?). It isn't a very balanced listening room with the TV in the corner, speakers at different heights etc. The room is approximately 13x15 but opens to the kitchen/table area which makes it more like a 13x30 space. I will be adding in wall/in ceiling surrounds in the future as well.
We listen to a mix of music, movies and TV. I don't have super discerning audiophile ear, but I do appreciate listening to the detail in music.
I am looking to move to smaller speakers book shelf speakers to replace the T45s to gain some floorspace back and make the room "look" a little better.
I am considering the Ascent Sierra-1s, Ascent 170s, and PSB B6s. I am leaning toward the Sierra-1, but don't really want to spend the money over the 170s if I am unlikely to see a big difference given my non-ideal configuration. Also given my inexperience in A/V, I am not sure what to expect compared to my current PSB T45 setup.
Any help or recommendations would be much appreciated.
dnadrifter is offline
post #2 of 6 Old 09-16-2013, 05:47 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Speaker placement and room interaction can make a huge difference on sound. You aren't going to gain floorspace by getting bookshelves because you still need speaker stands, unless you plan to put them on a shelf. If that is the case, you should look for something front ported.
I don't think upgrading your speakers is going to make a large difference in sound quality, I would instead keep what you have and see if you can improve the placement. Can you relocate the TV or maybe wall mount it? Perhaps post a layout and we can see if you have any good alternatives. If you have limited placement options now, your new speakers will face the same issue...
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 6 Old 09-16-2013, 07:36 AM - Thread Starter
dnadrifter's Avatar
Thanks for your feedback. The new speakers will go on bookshelf. The TV can't be moved as it is located in a built in cabinet. The left speaker will be on a bookshelf ear level. The right and center will be above the TV.
Curious though...if I put them on a shelf, why should they be front ported? Why would a manufacturer make a "bookshelf" speaker that wasn't optimal on a shelf?
post #4 of 6 Old 09-16-2013, 07:44 AM
Liked: 1319
That being said, since you already have the PSB Image C5, the Image B6 make the most sense. They are timbre matched and are an excellent speaker. Just make sure you have about 6" of space behind the speaker so as not to interfere with the port.
I think bookshelf refers more to the fact that they can be placed on a shelf, but the optimal location is on speaker stands.
post #5 of 6 Old 09-16-2013, 11:22 AM - Thread Starter
dnadrifter's Avatar
I am not sure it is the current C5 though. It is about 9 years old and seems to be a bit bigger in length.
post #6 of 6 Old 09-16-2013, 07:50 PM - Thread Starter
dnadrifter's Avatar
Just checked. It is a C40. I also have S10 dipoles in the garage.
Reply Speakers
