Needed help with speakers (Help to determine polarity) - AVS Forum | Home Theater Discussions And Reviews
Old 09-16-2013, 04:42 PM - Thread Starter
gurnoor's Avatar
I got my basement built recently and i got them to do some inside the wall wiring so i can set up a home theater. I bought a receiver now and i want to put my speakers in. The problem i'm facing is how to tell the difference between a red and a black wire(positive and negative). If you need more information please ask i will answer your questions so you can help me out. Are there any tricks to tell which side is positive and which is negative.
gurnoor is offline
Old 09-16-2013, 05:47 PM
Bill Fitzmaurice's Avatar
Liked: 4750
Touch the wires to a 1.5v battery, so that you can see the cones move outward. If they move inward reverse the wires so that they do move outward. The wire touching the + pole of the battery is positive.
Bill Fitzmaurice is offline
Old 09-16-2013, 05:54 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
what he said^^^^^^^^^
tubetwister is offline
