Need help with speaker setup - AVS Forum | Home Theater Discussions And Reviews
Old 09-16-2013, 10:10 PM - Thread Starter
ErikSkeries's Avatar
Hey guys. I have a denon avr-791 receiver currently set up with polk rm6750s in 5.1. I have the opportunity right now however to get 4 pioneer cs-t2100-k speakers. I was just wondering if it was a good idea to hook those up as the fronts and rears to my denon instead (i. E. Will the receiver handle them, will they actually sounds better, ect). Sorry for the dumb question but thanks in advance for any advice. Cheersz
EDIT: I should point out that I have a pioneer HTP-100CR center speaker that I could switch out the polk center for.
ErikSkeries is offline
Old 09-16-2013, 11:05 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
It's best for your front left, right, and center to timbre match. Generally, the best way to achieve that is to use three of the same speaker across the front, or a pair of left/right speakers and the matching center created by the manufacturer. It's next to impossible to predict (and highly unlikely) if mixing speaker brands will achieve this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
