Comparison of Veritas V6.3 and RC-70 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-17-2013, 08:00 PM - Thread Starter
liangh's Avatar
I bought a pair RC-70 to replace the RTI A7s about year ago. It is very hard to find a matching RC-LCR, so I bought a VERITAS V5.2c. It is sounds crisp compared to the RTI A6 and RC-70s. Impressed by the V5.2c, I was longing for VERITAS v6.3. Two weeks ago, Futureshop have sale at $800+Tax each. I grabbed a pair.
The initial comparison is very disappointed. The VERITAS sounds thin, edgy. The RC-70 sounds full, enveloping and balanced.
After two weeks break-in, the speaker has little improvement, but not much, particular at bass side. So I performed an accelerated “break-in” – playing the 30hz – 50hz test tone continuously for 8 hours at 85DB. That improves the bass a lot. Now the base sounds defined, punchy and extended.
The two sounds very differently. In general, the VERITAS sounds clearer and clean than the RCs. The base is better too after break-in. But it lacks the warmth and subtleness of the RCs. The Sibilant is more pronounced in VERITAS.
My impression of the VERITAS is more like a shining aluminum: bright, no color. The RC is more like copper: heavy and colored. Both has there its own character and attractive points.
To help people understand my impression, I record two clips of music. You can find it at here.
https://dl.dropboxusercontent.com/u/97096445/EnergySpeaker/female-vocal.flac
https://dl.dropboxusercontent.com/u/97096445/EnergySpeaker/male-vocal.flac
I also measured the response of the speakers with REW. You can found frequency response curve at here. Green is the VERITAS, Blue is RC-70 and Purple is VERITAS with Audyssey.
I am tore between the two speakers. The VERITAS cost double of the RC70s. The VERITAS sounds just marginally better than the RC-70s. I have to decide if I keep the VERITAS by this weekend. Your opinion is appreciated.
Here is my setup: Sony Blue Ray Player, Onkyo NR818 and a pair of R70 and a Pair of VERITAS v6.3.
liangh is offline
post #2 of 5 Old 09-17-2013, 08:33 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
I'm not quite sure how our opinion can change your decision. You've tested the speakers in your own environment and know the pros and cons of each. That's the best way to test and make a decision on speakers.
Keep the pair you like best and sell the other pair or use them as surrounds.
By looking at the photo with bare walls and hardwood floor some rugs and sound treatments might help tame the brightness of the V6.3.
Afro GT
afrogt is offline
post #3 of 5 Old 09-17-2013, 08:49 PM - Thread Starter
liangh's Avatar
Afro: you last point is the type of input I am looking for. smile.gif
liangh is offline
post #4 of 5 Old 09-17-2013, 09:11 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 143
That is a lot of money for what you think is only marginally better. I guess it depends how much that is worth to you. Sorry, I know that's not much help lol.
Gmash is offline
post #5 of 5 Old 09-17-2013, 11:58 PM
losservatore's Avatar
Quoted: 2648 Post(s)
Liked: 2427
Send me the VERITAS Ill keep then biggrin.gif I enjoyed both setups for a year , I had both VERITAS and RC complete 7.1 set ups, after a year with both setup I decided to keep the VERITAS and sell the RC.
The VERITAS 6.3 are a improvement.
losservatore is offline
Reply Speakers
Energy Rc 70 Floorstanding Speaker Black Ash Veneer , Energy V 6 3 Tower Speaker Single 3 Way Veritas Series Floorstanding Speaker
