KEF Q900 or Revel concetra f12 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-18-2013, 12:30 PM - Thread Starter
durell81's Avatar
I know there are dozens of these post about which speakers to choose. I also know that from reading dozens of post and reviews on different types of speakers that it is really a personal preference on which speaker sounds better. I am asking the question because I am also interested in resell value. I don't plan to buy speakers and resell them but hey you never know when you will have to liquidate.
I only have the option to audition the Revel concentra f12 and I like they way they sound, but they are already 7 yrs old. I don't have the luxury of auditioning the KEF Q900, but I have read several good reviews about them. So my question would be if the KEF Q900 sound as good as the Revel concentra F12 I would rather get the KEF's, but if they don't I will get the revel f12's
I am looking for suggestions from people who have heard one or the other or both. Any input provided would be really helpful.
durell81 is offline
post #2 of 16 Old 09-18-2013, 02:35 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
Those are both very good speakers, and the Q900 has awesome bass, which pretty much eliminates the need for a subwoofer.
On the other hand, for $1250 you can get a pair of Monitor Audio Silver RX6 speakers, which are better-sounding than either one IMO.
This has to one of the biggest bargains in audio today.
Stereophile likes them so much that they give them a Class B rating in Recommended Components. Most speakers rated Class B cost
$4000 to $8000 dollars.
commsysman is offline
post #3 of 16 Old 09-18-2013, 02:58 PM - Thread Starter
durell81's Avatar
Thanks for the speedy reply and the recommendation of the Monitor Audio Silver Rx6. I just worry about purchasing speakers without being able to audition them. Would you say the bass on the Rx6 is equal or better than that of the Revel f12's?
durell81 is offline
post #4 of 16 Old 09-18-2013, 03:29 PM
Quoted: 911 Post(s)
Liked: 489
I like the Q900, and I commissioned a nearfield monitor based on its 8" Uni-Q. However, if both of those speakers are the same price it's a no brainer. The Revel is just a much better-built speaker. The KEF has more interesting and higher-tech drive units - most $10k speakers are uncompetitive with the Q900 in that regard, but the cabinet is comparatively awful. The finish is much poorer, and it's not as well-designed, either. Basically, KEF seems to have blown the R&D budget designing those awesome drivers, and then had to trim costs everywhere else. That's why the crossover is rudimentary, and the cabinet finish quality is more in line with the $300/pr Infinity Primus than a Revel.
The Revel is a good, well-rounded speaker, with smooth and flat FR, well-controlled wide horizontal dispersion, more cone area than the Q900 overall (1-5-8-8 vs. 1.5-8-8) and solid bass tuning. If you can get a killer price just because it's an older design, then take advantage of it!
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #5 of 16 Old 09-18-2013, 09:11 PM - Thread Starter
durell81's Avatar
Thanks for that info! That really helps I didn't know if I should be turned off by the age of the speakers. After I left from auditioning them I didn't know if the sells man was just trying to move them out of stock to make room for the newer models. I can get them both for about the same price with the Revel concentra f12's being about $100 cheaper.
durell81 is offline
post #6 of 16 Old 09-19-2013, 12:12 PM - Thread Starter
durell81's Avatar
Hi I talked to the retailer and he is offering the Revel Concetra F12 for $999 a pair and the KEF Q900 are $1250 a pair. Is this a good enough deal to take the Revel F12 over the KEF's. I have only had the opportunity to listened to the Revel F12.
durell81 is offline
post #7 of 16 Old 09-19-2013, 12:26 PM
thrand1's Avatar
The F12's original MSRP was closer to the $1.5k range, so I think that is a good deal. In terms of product line age, Revel does not update products as frequently (it seems). The Concerta line is admittedly about 5 years old, but the Performa line went even longer between versions (version 3 was just released earlier this year, and I saw information on the Performa2's dating back to 2005!). I don't think the Concerta series will be updated anytime soon, but who really knows? smile.gif
Good luck with your search!
thrand1 is offline
post #8 of 16 Old 09-19-2013, 12:32 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
The F12's were also Class B rated by Stereophile. I owned a pair for a while and they were excellent speakers.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #9 of 16 Old 09-19-2013, 12:55 PM
bsinghrana's Avatar
durell81, where do you have Q900 for $1250 a pair? I am after them and amazon list them at $899 single.
bsinghrana is offline
post #10 of 16 Old 09-19-2013, 01:59 PM - Thread Starter
durell81's Avatar
Hi bsinghrana,
I have $550 saved from cash back purchases on my discover card and I can use that through Amazon. So it's not exactly a sale. The revels concentra f12 I am able to get locally at that price.
durell81 is offline
post #11 of 16 Old 09-19-2013, 06:47 PM
Avgass's Avatar
Liked: 35
Get the Revels and use the $550 for something else? Seems like a smarter way to go especially if you've heard and like the F12s.
Also, just cos a speaker is old does not mean it's not a good speaker.
Avgass is offline
post #12 of 16 Old 09-21-2013, 06:49 AM - Thread Starter
durell81's Avatar
Avgass thanks for the reply! I will probably make a decision today.
durell81 is offline
post #13 of 16 Old 09-22-2013, 09:01 PM - Thread Starter
durell81's Avatar
I finally pulled the trigger on the revels. My local dealer had a sale and I was able to walk out with a pair of f12s and a c12. Thanks everyone for the feedback.
durell81 is offline
post #14 of 16 Old 09-24-2013, 01:10 AM
Avgass's Avatar
Liked: 35
Awesome. The C12 is a great centre speaker and it's so important to match your front soundstage so getting the C12 at the same time was a really good move. Let us know your impressions once they're all set up at home
Avgass is offline
post #15 of 16 Old 10-22-2013, 05:52 PM - Thread Starter
durell81's Avatar
I have it all hooked up and I used the extra money to snag a sherbourn pa 2-160. I really like the way it sounds.
durell81 is offline
post #16 of 16 Old 10-22-2013, 09:44 PM
Avgass's Avatar
Liked: 35
Good to hear - literally
Avgass is offline
Reply Speakers
Kef Q900bl Black Floorstanding Speaker Each , Kef Q900wa Floor Standing Speaker , Kef Q900 2 5 Way Q Series Floorstanding Speaker Each , Revel Concerta F12
