Klipsch reference series - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-20-2013, 08:56 AM - Thread Starter
jbormes96's Avatar
Here is my current set up:
Pioneer vsx 1021 reciever
Klipsch reference rb 61 as fronts
Klipsch synergy b20 as backs
I was running an energy cc10 center Chanel but I was wondering if I need to upgrade and match the fronts. With a reference rc 62 or rc 52?
Is there much of a difference?
I haven't opened the reference rb 61, will they be good for movies and music? With enough power? Are they more powerful then the synergy b 20? I plan to bi amp the rb 61
What's a good subwoofer I can purchase to go with my set up?
jbormes96 is offline
post #2 of 4 Old 09-20-2013, 11:15 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
I would definitely upgrade the center to match the fronts. Go with the RC-62 if you can fit it.
The rears are fine for surround duty.
What budget do you have for the subwoofer?
I would recommend upgrading your receiver if you can.
The RB-61 are great for fronts and there is no need to bi-amp them.
ifor is offline
post #3 of 4 Old 09-21-2013, 09:24 AM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Reference and synergy are pretty far apart. I would upgrade your center and your back speakers to reference. You will be glad you did. You want that ti horn all around you.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #4 of 4 Old 09-25-2013, 08:30 AM - Thread Starter
jbormes96's Avatar
Am I going to see a lot more power with the rb61 and the rc62? Is it fine to use the synergy as backs/surrounds?
Reply Speakers
Klipsch Rb 61 Ii Reference Series Bookshelf Loudspeakers Black Pair , Klipsch Synergy B 20 Premium 5 25 Inch Bookshelf Speakers Pair , Energy Cc 10 Center Channel Speaker Black , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Pioneer Vsx 1021 K 7 1 Home Theater Receiver
