Upgrading an old System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-21-2013, 05:35 PM - Thread Starter
volitan83's Avatar
It has been a while since I purchased some of the speakers in my home theater system, so I was wondering if I should invest in some new ones.
I currently have 7.1 setup with an Athena WS-60 for my center, 4 Sony SS-MF400H for the Front Left/Right and Surround Left/Right, 2 Athena WS-15 for the Back Left/Right and a Klipsche RW 12d for the sub. The receiver is a Pioneer VSX-92TXH in a roughly 14x14 room.
I would be looking for something mid-range like the Athena's used to be. I assume that puts me at spending around 200 to 400 per speaker. As such, is it worth upgrading, and if so, what should I be looking at?
For a nice added twist, my wife hates the size of the Sony's so something smaller and still quality wouldn't hurt (again like the Athenas used to be).
volitan83 is offline
post #2 of 5 Old 09-26-2013, 02:58 PM - Thread Starter
volitan83's Avatar
I've been scouring the forum for some more info on what I should do without much results.
Any suggestions on what I should do here?
I am using the setup for 50/50 movie/video games usage. I am mainly looking for middle of the road speakers, which looking at other posts, puts me at ~$500 per pair I think.
post #3 of 5 Old 09-26-2013, 03:04 PM
zieglj01's Avatar
Quoted: 1683 Post(s)
Liked: 1585
Changing depends on you and taste - there are better options than the Athena's and Sony
Look at HSU
http://www.hsuresearch.com/speakers.html
http://www.hsuresearch.com/products/hybrid2pkg.html
Look at Focal
http://www.musicdirect.com/search.aspx?searchterm=focal%20chorus
http://www.accessories4less.com/make-a-store/brand/focal/results/1.html
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 5 Old 09-26-2013, 03:52 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
A pair of Wharfedale Diamond 10.1 speakers costs $350. I suggest that you buy four of those for $700 plus a matching Wharfedale 10CC center speaker for around $200.
These will sound way way better than the Sony speakers.The improvement will be huge and dramatic. I suggest that you read the Stereophile review of them at their website.
Not only are the 10.1 speakers MUCH better-sounding than the Sony speakers, having the center speaker matched to the others also will be a major improvement.
Set this up as a 5.1 system and I think you will love it. You can try adding 2 of the other speakers later and see if that really adds anything.
commsysman is offline
post #5 of 5 Old 09-26-2013, 04:53 PM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
The andrew jones designed pioneer speakers have a lot of high end engineering for a great price.
The next clear step up from them that I can think of are kef q100s at accessoriesforless. Kefdirect sometimes had them on sale too. I really can't stress enough what great value they are.
SyntheticShrimp is offline
Reply Speakers
