Recommendations for a 7.1 Speaker setup for a Baffle Wall in 5-8K range - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2013, 07:05 AM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
Looks like it's down to JTR, Triads and Pi speakers. With 2 subs the Triads are coming out to be cheaper.
smuggymba is offline
Old 09-24-2013, 08:35 AM
MKtheater's Avatar
Quoted: 1624 Post(s)
Liked: 1158
The PI speaker will also be too wide if using the 15 inch driver. I would say down to JTR and Triads. Any Danley speakers that fit the size and budget?
Marantz 7702 Atmos
MKtheater is offline
Old 09-24-2013, 08:55 AM
Mike Garrett's Avatar
Quoted: 5750 Post(s)
Liked: 3704
None of the Danley stuff will work. They are wide and very deep. A SM60F is 20.6" deep. Also 20.6" wide. The SM60M is 20.6" x 20.6" x 16.3" deep. Way above budget also. The front three would be above the top end of his budget.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 09-24-2013, 09:01 AM
MKtheater's Avatar
Liked: 1158
Same size as the smallest BFM DR, the DR-200 which is too big for the OP. The Klipsch THX ultra 2's are nice but you need a deal on them. I don't like them at retail as I would go JTR 228 instead. The Sho-10's would have been a good option but the SEOS would be a replacement. Which Triads are we talking here, I would take JTR's over any Triad under the golds. Golds and up it is a preference thing.
idratherbeflying likes this.
Marantz 7702 Atmos
Old 09-24-2013, 09:13 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
You might also consider the JBL LSR6332 monitors. They are $1560 shipped each. They are some of the best measuring speakers you can buy at any price. They are THX pm3 certified which means they can be used to mix and create THX sound tracks- that is NOT an easy certification to get. They won't have the dynamic range of Pi, JTR, or JBL cinema, but they will still pack a punch and be more accurate besides. According to this SPL calculator they could still hold reference level sound in your room with headroom to spare. If it were me, it would be a choice between the JBL LSRs and the Pi Fours. The Pis will have great accuracy and insane dynamic range and the JBLs will have great dynamic range and have unmatched accuracy. If you want a speaker with similar levels of performance, you will have to work your way up to the higher end $11k pair Genelec monitors (very nice!), the $20k Revel Salon 2s, or some crazy expensive JBL Synthesis setup.
If the Pi Fours are too big, consider the Pi Threes. The Pi Three measurements have flatter on-axis measurements anyway, and they will still have lots of headroom to spare. As with the Fours, I would get them with upgraded drivers. The Threes have terrific measurements.
shadyJ is offline
Old 09-24-2013, 09:24 AM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
Remember guys, the front wall will be a baffle wall so I need the LCR to fit on those.
I'm going to buy Genelacs or something better when I win the lottery; in the meantime I need something sounding good in the 7K range biggrin.gif So far awesome info, can't thank you guys enough.
Which is cheaper - Triads or JTR's (with one sub, will add a second sub later)
Old 09-24-2013, 09:36 AM
Liked: 3704
Triads.
Old 09-24-2013, 09:51 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Triads.
You must be talking about Triad Silvers when you said triads are cheaper right?
jbrown15 is offline
Old 09-24-2013, 10:16 AM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
Originally Posted by jbrown15 View Post
You must be talking about Triad Silvers when you triads are cheaper right?
http://www.triadspeakers.com/products/intropagelcrscenter.html
Old 09-24-2013, 11:32 AM
jbrown15's Avatar
Liked: 1993
I guess if you're set on inwalls then yeah definitely get Triads. Personally unless you absolutely have to go with inwall speakers because of space I just think its a waste to get them. It limits you in a lot of ways and then have lesser performance when compared to say Triad Silver monitors for example.
jbrown15 is offline
Old 09-24-2013, 11:35 AM
MKtheater's Avatar
Liked: 1158
Why get inwalls if you are building a baffle wall?
Marantz 7702 Atmos
Old 09-24-2013, 11:58 AM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
The in-wall recommendation was for the surrounds...the baffle wall will be in the front for LCR's.
Old 09-24-2013, 12:43 PM
MKtheater's Avatar
Liked: 1158
Skip the SVS subs, get dual Cap 2400's passive and run a single 5000 watt amp on them for the same price!
Marantz 7702 Atmos
Old 09-24-2013, 01:40 PM
shadyJ's Avatar
Liked: 1350
+1 on this. The caps will be a lot better.
shadyJ is offline
Old 09-24-2013, 03:27 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Nothing on my Cap S2 reco?
ifor is offline
Old 09-24-2013, 06:31 PM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
Old 09-24-2013, 07:20 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Just use one.
ifor is offline
Old 09-24-2013, 07:25 PM
jbrown15's Avatar
Liked: 1993
Above 20hz a Cap 2400 has the same output as a Cap S2! Just something to think about.
The passive version of the Cap 2400 is available for only $1499 from JTR.
jbrown15 is offline
Old 09-24-2013, 08:58 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
But the S2 would be able to fit in the baffle wall.
ifor is offline
Old 09-25-2013, 05:22 AM
Liked: 3704
To do this, you will need some DSP to EQ the subs. You will also need a calibrated mic with software to measure the response, so that you know where and how much EQ is needed.
Old 09-25-2013, 06:49 AM
MKtheater's Avatar
Liked: 1158
Is he going to tweak like that? If not then he could just use audyssey and be done. He will need to do that for any sub in a room if need be. The DSP in amps te to get a flat response, boost low end if needed, limiters, and or filters. Once you put a sub in a room that flat response out of the box is bye bye. The sub is ported so the tune takes care of the low end. His ears will be the limits not the sub. All he would need would be HP filters unless he buys two and doesn't run really loud. I would take dual passive Caps with CV-5000 all day than dual PB 13's.
Marantz 7702 Atmos
Old 09-25-2013, 07:00 AM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
So Cap S2 is smaller and will fit in the baffle wall while SVS Ultra is big? Going to check their dimension now.
Old 09-25-2013, 07:27 AM
MKtheater's Avatar
Liked: 1158
Well the CapS2 will have about the same output as dual PB13's from 15-40hz. I will have double below 15hz and above 40hz.
Marantz 7702 Atmos
Old 09-25-2013, 09:04 AM
Liked: 3704
The S2 will not have anywhere close to that response, if he does not use the DSP amp that Jeff has set up for that sub. Just sticking a CV5000 on it is not the same thing. You can have the same thing if you use the CV5000, a device to add DSP, a calibrated mic with software and measure and set up the DSP correctly. Not a plug and play system.
Added
From the S2 specs: "4000 watts RMS, class D, DSP optimised"
Old 09-25-2013, 09:54 AM - Thread Starter
smuggymba's Avatar
Quoted: 113 Post(s)
Added
How much is this DSP amp? What range? So basically, with this DSP amp Cap S2 won't be fully utilized..right?
Old 09-25-2013, 11:52 AM
MKtheater's Avatar
Liked: 1158
This is not my dual passive caps option, I am referring to the capS2 which is powered.
Marantz 7702 Atmos
Old 10-14-2013, 08:19 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Any word on what the OP is going with?
ifor is offline
