Speaker Cable - 8 Gauge vs. 10 Gauge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-24-2013, 04:53 PM - Thread Starter
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
Is there really a huge difference in the sound quality between an 8 Gauge or 10 Gauge speaker cable?
The only thing I notice difference is that the 8 Gauge speaker cable is thicker.
Thanks for any advice!
mantaraydesign is offline
post #2 of 15 Old 09-24-2013, 04:58 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Nope.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #3 of 15 Old 09-24-2013, 05:02 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
nada,nil,zip,na,nyet....
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #4 of 15 Old 09-24-2013, 05:10 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
Thanks guys!
Maybe I can save some money if I buy the 16 Gauge speaker cable. The 16 Gauge is pretty thin compare to the 8 Gauge but the sound quality will sound the same anyway.
post #5 of 15 Old 09-24-2013, 05:21 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
http://www.roger-russell.com/wire/wire.htm
Chu Gai is offline
post #6 of 15 Old 09-24-2013, 05:25 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Can't imagine where you'd need 8 awg cable for speakers. For that matter, even 10 awg. (unless your speakers are a LONG ways away)
crn3371 is offline
post #7 of 15 Old 09-24-2013, 05:27 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
It's manly.
Chu Gai is offline
post #8 of 15 Old 09-24-2013, 05:34 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I can't imagine trying to fit 8 awg in banana plugs or binding posts.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #9 of 15 Old 09-24-2013, 05:44 PM
Bill Fitzmaurice's Avatar
Liked: 4628
Originally Posted by mantaraydesign View Post
Thanks guys!
Use this to find out what you actually need:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Bill Fitzmaurice is online now
post #10 of 15 Old 09-24-2013, 06:13 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
You think 8 awg is huge, you should take a look at the 4 awg. Yes, I just found out that they make the massive 4 awg speaker cable. LOL
post #11 of 15 Old 09-24-2013, 06:15 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
I will give that a try.
post #12 of 15 Old 09-24-2013, 06:15 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
Great information and thanks!
post #13 of 15 Old 09-24-2013, 07:57 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
I have another question.
When you connect the speaker cable to the back of the speaker, do you use the Banana Plug connector or do you use the bare wire?
Here is a picture:
Processed By eBay with ImageMagick, z1.1.0. ||B2
Again, do the Gold plated banana connectors make huge improvement on the sound quality? Or is it just another hype marketing?
post #14 of 15 Old 09-24-2013, 08:18 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
You can use whatever floats your boat and that includes pins and spades. IMO, using connectors is a neater and more elegant, if you will, way of joining two pieces of equipment and avoids the possibility that a stray wire causing a short. BTW, not all gold connectors are actually gold and the thickness of the coating does vary. What gold does is provide a surface that is not attacked by chemicals which includes oxygen. Don't overly obsess over the minutiae.
Chu Gai is offline
post #15 of 15 Old 09-24-2013, 08:23 PM
Liked: 4628
I use bare wire, except for my pro-sound gear, which has connectors because I plug them in at the beginning of the night, and unplug them at the end.
They make no difference. Gold isn't a very good conductor, it's used because it won't corrode. That's significant if your system is on a boat or in a house near the ocean, but otherwise, not really.
Reply Speakers
