$1500 for a 3.1 sound system. best bang for the buck. need help from the AVS community. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 64 Old 10-02-2013, 02:24 PM - Thread Starter
Truquitos's Avatar
Guys, any recommendation on a good brand for the AVR that equalizes the subwoofer? or any feature I should look when picking out a AV Receiver? for the speakers I'm looking into ARX, KEF, HTD. Any other good brand for floorstanding speakers I should be looking into? Thank you all for the help so far!!
Truquitos is offline
post #62 of 64 Old 10-02-2013, 02:44 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
All brands of AVR that have different models also put different strengths of automatic equalization in different models. So I can tell you to get a Denon, an Onkyo or a Marantz and you could still get an AVR that does subwoofer equalization poorly.
Basically you probably want an AVR that has Audyssey Multieq XT32 , along with Audyssey Subeq XT.
It will be in the AVR feature lists,
You probably want to go with a subwoofer which makes floorstanders optional to say the least. I don't know of any floorstanders with built in subwoofers that can compare to even just a mid-range subwoofer.
arnyk is offline
post #63 of 64 Old 10-02-2013, 06:49 PM - Thread Starter
Truquitos's Avatar
Maybe I expressed myself wrong. I will be getting a sub either a Rythmik LV12R or HSU VTF-2 Mk4. So, an AVR that can equalize the sub will be good. and for the floorstanding just wanted to know a few others good brand within my budget "AVR, sub and speakers"
post #64 of 64 Old 11-24-2013, 10:49 AM
New 2 HT's Avatar
HI All,
i have Yamaha RX-v773 AV and Outlaw M8 Sub (purchased last week). Looking for speakers to setup 5:1 system. My current room size is 10x12 and in future 13x15
Want to check with the experts
a) if A2rx-c LCR or A3 L&R and A2rx-c as Center be a good blend for the Rvr and sub i have?
b) What is the budget surround speakers that could fit in this setup? i will be wall mounting.
Thanks in advance.
New 2 HT is offline
Reply Speakers
Yamaha Rx V673 Receiver , Rythmik Audio Lv12r , Denon Avr E300
