How would you build a hardwood bookshelf speaker stand? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-26-2013, 02:06 AM - Thread Starter
Coolnewbie's Avatar
I have access to decent wood plus a relatively cheap carpenter or can try a well informed DIY approach.
How would I build the best possible speaker stand out of hardwood? About a meter high sounds right. Should I put rubber or some other padding on the base plate where you place the speaker or on the stand base where it meets the floor? Any good way to conceal wires?
Coolnewbie is offline
post #2 of 5 Old 09-26-2013, 01:42 PM - Thread Starter
Coolnewbie's Avatar
Or does anyone have any good samples?
post #3 of 5 Old 10-16-2013, 09:57 AM - Thread Starter
Coolnewbie's Avatar
So no special property of good stands other than height and stability?
post #4 of 5 Old 10-16-2013, 12:25 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
You may want to look in another section of the forum for this info.
Here is a link for ya...
http://www.avsforum.com/f/19/dedicated-theater-design-construction
I recently built me some bookshelf stands, but I kinda went overboard with stability with them, but that is ok..
There is a link below my post that will kinda show you what they look like, but I didn't explain how I built them.
I have some large speakers, so that is why I went for a sturdy build.
Monitor Audio RX2's
HAMP568 is offline
post #5 of 5 Old 10-16-2013, 03:40 PM
wdeydwondrer's Avatar
Quoted: 30 Post(s)
Liked: 27
My best advice to you if you are trying to produce a very nice, finished product is to enlist a cabinet man, not just a run of the mill carpenter.  Being a cabinet maker myself I shudder every time I see a cabinet/furniture made by todays carpenters.  A finish carpenter though is a some what different story.  Hardwoods can also be a pain if you don't have some really good lumber to start with and someone that knows how to work with it.
My biggest recommendation though, since working with hardwoods can get expensive in a hurry, take your time designing them on paper first.  Since you're going after a custom stand, ALL aspects of it are up to you.  The height should be restricted to around where the tweeter would be at ear level with the speaker on top (for smaller speakers, my stands usually wind up being around 30 inches tall).  But the base, feet, wire chases, these are all up to your own designs.  Stability isn't really a problem if you keep the center of gravity in mind.  The base will almost ALWAYS be the same size as the top pedestal or larger.  You can also do things like weight the base internally/on the bottom too.  There's no real design to keep it up right if you run straight into it though.
wdeydwondrer is offline
Reply Speakers
