Boston Acoustics A26 Loudspeakers in a closed cabinet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-26-2013, 02:48 PM - Thread Starter
sean101's Avatar
Hello! I am considering using three A26 Loudspeakers for my R-L-C for part of a 5.1 surround system. It will be 80% for watching movies.
Will I have any issues if the speakers are in a closed cabinet? I am also considering NHT Absolute Zeros, so any feedback would be welcome.
Thanks for your help!
sean101 is offline
post #2 of 3 Old 09-26-2013, 05:50 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
Are you gonna leave the cabinet closed while you listen to them?
Do you have a pic of the cabinet?
Afro GT
afrogt is offline
post #3 of 3 Old 09-27-2013, 09:40 AM - Thread Starter
sean101's Avatar
Good question! Thanks afrogt!
Here is a rendering of the cabinet. R-L-C stored up top and a sub down below, with the components stored to the right of the tv. Will use in-wall for the backs. As you will see, the scale is a little off, but this pretty much how it will look.
sean101 is offline
Reply Speakers
Boston Acoustics A 26 Two Way Bookshelf Speaker With 6 5 Inch Woofer Each Gloss Black , Boston Acoustics A26 White Ea 2 Way Bookshelf Speaker
