Revel F208 or Klipsch RF-7II - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 167 Old 09-26-2013, 11:27 PM - Thread Starter
RefTheater's Avatar
I am building a Home Theater and i would like to hear an opinion from all the members that can help me decide.
I've heard Klipsch RF-7II and Revel F208, but with different amps.
The Revel seemed to be a much superior speaker, i don't know if the amp made the difference. I am tempted to go with Revel in Piano Black.
Since it's a living room i must put a speaker that is beautiful also.
RefTheater is offline
post #2 of 167 Old 09-27-2013, 07:14 AM
SyntheticShrimp's Avatar
Quoted: 241 Post(s)
Liked: 210
I've heard both. I've owned the klipch rf-82 and revel m105. The win goes to the Revel, no contest. The Revel is about is good as they get.
SyntheticShrimp is offline
post #3 of 167 Old 09-27-2013, 08:08 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Think no further.
AcuDefTechGuy is offline
post #4 of 167 Old 09-27-2013, 11:13 AM
jima4a's Avatar
Quoted: 281 Post(s)
Liked: 153
The Kef R900 would be one of the only other speakers I would consider in comparison to the F208 and that would simply be a preference / room thing. Revel would be my choice based on the OP's selection options.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #5 of 167 Old 09-27-2013, 11:53 AM
Quoted: 175 Post(s)
Liked: 262
Absolutely. KEF R900 & Revel F208. They are a toss-up. Almost like twins. biggrin.gif
post #6 of 167 Old 09-27-2013, 03:39 PM
Quoted: 241 Post(s)
Liked: 210
The R900 is a great recommendation. I'd still have to give the very slight nod to the Revel because of the wider dispersion.
post #7 of 167 Old 09-27-2013, 04:28 PM - Thread Starter
RefTheater's Avatar
I would prefer to buy the JBL LS80 in a second compared to Kef R Series. I like Kef, but for Home Theater is much better Revel or JBL Synthesis.
The JBL Synthesis LS Series are also speakers for me to consider...they have the "boom factor" extremelly important to make movies come alive. Or by the other hand i will go Revel.
Klipsch is a nice speaker, and here talking of the RF-7II, but not as refined as the ones i mentioned...
post #8 of 167 Old 09-27-2013, 05:31 PM - Thread Starter
RefTheater's Avatar
I am wondering if the LS Series connected to a Pre/Pro or High End Receiver if they perfom as well as being connected to JBL Pre/Pro...
I know that for the "Array" Series it makes difference....
post #9 of 167 Old 09-27-2013, 06:18 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Price wise are you comparing them as equivalent?
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #10 of 167 Old 09-27-2013, 06:35 PM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
I hope not the revel retail for 5k. Almost 2k more than the rf-7ii.
SanchoPanza and woodeka like this.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #11 of 167 Old 09-27-2013, 06:41 PM
Quoted: 197 Post(s)
Liked: 511
Don't know much about either; but, do know that's not the top of the line Klipsch.
Is that the top Revel?
post #12 of 167 Old 09-27-2013, 07:54 PM
jima4a's Avatar
Quoted: 281 Post(s)
Liked: 153
The F208 is the top of the mid line Revels, Performa3s. The Salon2s are the top of the Revel upper line, Ultima2s. I have heard the Studio2s, driver size close to the F208s, which were amazing. If the F208s are close to the Studio2s - and am told they are - they will be fabulous.
SanchoPanza likes this.
jima4a is offline
post #13 of 167 Old 09-27-2013, 08:10 PM
Quoted: 197 Post(s)
Liked: 511
Thanks. I'm told you can buy five (5) RF-7II for $5K. FCR + 2 Surrounds will be Wonderful; if he has the room.
Don't know the street price of the Revels, though.
post #14 of 167 Old 09-28-2013, 05:15 AM - Thread Starter
RefTheater's Avatar
Even if with 5k i buy 5 RF-7's, i prefer 2 Revels F208. Klipsch finish is so, but so "cheap", when you look at them from a certain distance they look very good, with the gold woofers, but then they are made of "MDF", that's not even wood.
Besides Revel does not only has a good finish but it's sounds amazing, for CInema is spectacular. But i haven't decide, because JBL LS80 is not so "sweet" playing music, but it has more "kick" for Cinema. It's also cheaper than Revel, and much better finished than Klipsch.
post #15 of 167 Old 09-28-2013, 05:20 AM
Quoted: 197 Post(s)
Liked: 511
OK, I'm sure you'll love them.
post #16 of 167 Old 09-28-2013, 06:36 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Sounds like you didn't need to start this thread then.
MDF is pretty standard now for speakers cut by CNC as it doesn't chip and has more uniform characteristics from most plywood. Are Revel speakers made from solid wood?
Perhaps rename the thread "Revel F208 or JBL LS80" then?
psgcdn is offline
post #17 of 167 Old 09-28-2013, 06:43 AM
Quoted: 197 Post(s)
Liked: 511
I'm sure I'm preaching to the choir, but you'll need lots of power for the Revel, being relatively inefficient; although I'm sure they all can benefit from more "horsepower".
post #18 of 167 Old 09-28-2013, 07:18 AM
MUDCAT45's Avatar
Quoted: 389 Post(s)
Liked: 289
Another Klipsch fan boy I see.smile.gifsmile.gif Just kidding. I recently sold my Klipsch KG2 and KG4 speakers. I have also owned RF7's.
I still have KG 5.2 and Revel F32. I know you are familiar with all the debate on Klipsch forum about power amps needed for RF 7's. Having owned them I agree. They need as much power as the Revels to properly perform.
The Revels do open up a little more at louder levels but so do the KG5.2's as their efficiency is low 90's.
Bottom line is the Revels will play as good as Klipsch with any given amp/AVR in my experiences.
MUDCAT45 is online now
post #19 of 167 Old 09-28-2013, 07:39 AM
Quoted: 197 Post(s)
Liked: 511
Why, yes, yes I am; but, at this stage I personally wouldn't have either.
Doesn't mean the Revels won't be a pure joy for him.
I should've said the Revels will require more power to drive to reference level; but, I'm sure he plans P, for plenty, at any rate.
post #20 of 167 Old 09-28-2013, 08:55 AM
Vital's Avatar
Liked: 34
The Revel is a fine speaker but it is in a different class than the RF-7 for sure. It is the same price difference between the two as if we compare the Revel F208 to the Klipsch P-37F. Klipsch P-37F
psgcdn and SanchoPanza like this.
Vital is offline
post #21 of 167 Old 09-28-2013, 09:15 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
And I wouldn't use any of them in an HT room, personally. Stereo in living room, for sure; very nice speakers. Am I wrong or is this thread more about living room stereo more than backroom HT?
psgcdn is offline
post #22 of 167 Old 09-28-2013, 09:18 AM
Quoted: 197 Post(s)
Liked: 511
OP mentioned HT in 1st post.
post #23 of 167 Old 09-28-2013, 11:21 AM
avfunny's Avatar
Originally Posted by jima4 View Post
The Kef R900 would be one of the only other speakers I would consider in comparison to the F208 and that would simply be a preferenceEoRNcT/room thing. Revel would be my choice based on the OP's selection options.
They look the same.
avfunny is offline
post #24 of 167 Old 09-28-2013, 12:14 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
He mentions HT in a living room... and talks about a pair of speakers rather than 5.1.
psgcdn is offline
post #25 of 167 Old 09-28-2013, 12:17 PM
Quoted: 197 Post(s)
Liked: 511
Perhaps he'll clarify.
post #26 of 167 Old 09-28-2013, 01:45 PM
MUDCAT45's Avatar
Quoted: 389 Post(s)
Liked: 289
Speaking from experience the Revel F32 is as good as the RF7 for HT and superior for music. The Reference speakers have poor mids for music.
Have your tried both?
post #27 of 167 Old 09-28-2013, 02:01 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
No, I just prefer bigger horns for HT for dynamics so wouldn't pick those for HT (you have introduced yet another model BTW; I wonder if an 86 dB sensitivity speaker can be as dynamics as big horns). Not that big horns aren't good for music; I can sip wine while I pinpoint the instruments in front of me like any other audiophile.
psgcdn is offline
post #28 of 167 Old 09-28-2013, 02:18 PM
Quoted: 241 Post(s)
Liked: 210
Dynamics are relative. Important things to consider are room size and preferred listening levels. If you have a large room and like to listen at reference levels or more, then you will probably want horn speakers. A horn speaker shouldn't be any more dynamic than a traditional cone and dome/ waveguide speaker given that both aren't driven to thermal compression, but that can be a big caveat depending on your situation.
post #29 of 167 Old 09-28-2013, 03:18 PM - Thread Starter
RefTheater's Avatar
Sorry guys i didn't clarified. So at the momment i have 2 options on the table, and Klipsch is not one of them:
JBL Synthesis:
- LS80 (Front) x 2
- LS Center
- LS60 (Back Surrounds) x 2
- SVS Subs Ultras x2
Revel:
-F208 (Fronts) x2
-C208 (Center)
-F206 (back) x2
-B112 (Sub) x2 or SVS Ultras x2
Prices of JBL are cheaper, and to be honnest i am tempted to go JBL, and the min reason is that is more adequated speaker for cinema, and looks good on the living room.
post #30 of 167 Old 09-28-2013, 03:34 PM
Quoted: 197 Post(s)
Liked: 511
What percentage Music Vs. Cinema?
Reply Speakers
Klipsch Rf7ii Reference Ii Flagship Floorstanding Speaker Black B Stock , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker Cherry B Stock , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker
