Budget Speakers - Head is spinning - Need to make decision soon - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 09-30-2013, 10:31 AM
Kini62's Avatar
Quoted: 1421 Post(s)
Liked: 1307
Originally Posted by NAIM101 View Post
To fill a room that size you will need to increase your budget pretty much. There is no point in getting the subwoofers you listed because its gonna bottom out and not even be worth buying initially. Save up and get a bigger sub like the VTF-15H from Hsu or the SVS or the Outlaw.
From 40hz and up the PA150 pretty much matches the the VTF15. So if the OP is not concerned with filling 3000 cubic feet with low bass (which cannot be done adequately with $500) he might as well fill in the mid bass and at least get some good punch.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #32 of 32 Old 09-30-2013, 10:39 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
While the PA-150 will certainly have more output, the PB-1000 is roughly equivalent to the PB12-NSD in that same range. So the PB-1000 will do very well and would likely satisfy many people. See Ed Mullen of SVS's explanation:
Originally Posted by Ed Mullen View Post
The PB12-NSD has about 50% more max output than the PB-1000 in the 18-36 Hz octave (they have similar max output in the 40-80 Hz octave). So subjectively the PB12-NSD will provide greater levels of slam/impact/pressure at higher playback levels in that size room. Whether or not you would actually realize that difference at playback levels which are 'a bit above average' is really the question you need to answer. . . .
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Infinity Primus P363 Three Way Dual Infinity Floor Standing Speaker
