Advice For Soundbar/3.1/LCR Options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-28-2013, 05:35 PM - Thread Starter
pacettr's Avatar
I'm almost finished with a dedicated HT.  I'm robbing most of my existing speakers from the living room (Klipsch F-3, C-2) so I'm looking for options to replace my existing setup.
I believe I've settled on a Samsung UN75F6400.  I was exploring soundbar options, but remembered I have a Yamaha AVR (mid-range model that's ~ 5 years old; I'll update with the model # later if it's relevant) that I'm upgrading for the HT.  Is it possible to run a 3.1 setup that will sound good?  Should I stick to a decent pair of book shelf speakers?  Or maybe something like the Klipsch G-42?
I also have the option to use my current sub (Klipsch 10") and get an upgrade for the HT, but I think I would rather have something with a bit slimmer design for the living room.
Opinions and suggestions welcome :)
pacettr is offline
post #2 of 7 Old 09-28-2013, 07:40 PM
zieglj01's Avatar
Quoted: 1562 Post(s)
Liked: 1411
I would skip the soundbar - and go 3.1 with bookshelves and center speaker.
If you want small - then look at Cambridge Audio
http://www.accessories4less.com/make-a-store/item/CAMBS30OAK/CAMBRIDGE-AUDIO-S30-4-2-way-Bookshelf-Speakers-Pair-Dark-Oak/1.html
http://www.accessories4less.com/make-a-store/item/CAMBS50OAK/CAMBRIDGE-AUDIO-S50-4-3-Way-Center-Channel-Speaker-Dark-Oak/1.html
Or, NHT SuperZero speakers
http://www.nhthifi.com/Bookshelf-speaker-SuperZero-2-1?sc=12&category=3772
Do you have some type of budget?
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #3 of 7 Old 09-28-2013, 10:08 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Either of these could be good setups, although I would lean toward the Cambridge. Then you just need a good sub smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 7 Old 09-29-2013, 12:50 AM - Thread Starter
pacettr's Avatar
No set budget, but I don't intend to get crazy.
Will the AVR sound ok without rear speakers? No "missing sound" etc? Just leave it in 5.1 mode and hook up bookshelves and a center?
pacettr is offline
post #5 of 7 Old 09-29-2013, 06:39 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
You might want to consider getting four of the Pioneer BS-22 speakers, which are VERY good and cost only about $130 per pair.
Then get a matching Pioneer center speaker.
To get an idea how great those are for the money, check out the review Stereophile did on them recently.
commsysman is offline
post #6 of 7 Old 09-29-2013, 07:26 AM
Chevypower's Avatar
Liked: 40
Forget the soundbar, I think they sound terrible. Use your Yamaha AVR and get an Ascend CMT-340SE center + 2 CBM-170SE bookshelf speakers. Sanus makes suitable stands for them.
ascendacoustics.com
If you ever decide to add more speakers, a sub, or update your AVR, it's nice to know you can.
Chevypower is offline
post #7 of 7 Old 09-29-2013, 07:45 AM
zieglj01's Avatar
Liked: 1411
You can set the AVR to 3.1
Who AM I
zieglj01 is offline
Reply Speakers
