Infinity Primus PC351 vs the polk cs10 center war - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-29-2013, 12:00 AM - Thread Starter
KennyPa's Avatar
I've been looking at these two speakers and I'm on ready to pull the trigger on one of them. I was wondering which one would you guys choose?
KennyPa is offline
post #2 of 7 Old 09-29-2013, 10:57 AM
afrogt's Avatar
Quoted: 1437 Post(s)
Liked: 982
Get the one that matches your other two front speakers. If you have Infinity fronts get the PC 351, if you have Polk fronts get the CS10.
The Infinity center is much larger than the Polk.
crazyrob425 likes this.
Afro GT
afrogt is online now
post #3 of 7 Old 09-29-2013, 11:29 AM
bladerunner6's Avatar
Quoted: 22 Post(s)
Liked: 59
Absolutely get the matching center.
+1
bladerunner6 is offline
post #4 of 7 Old 09-29-2013, 02:49 PM - Thread Starter
KennyPa's Avatar
I have fronts form my older HITB. I'm replacing the speakers piece by piece. I already have a new AVR. I've heard Polks quality went down. Is that true?
KennyPa is offline
post #5 of 7 Old 09-29-2013, 03:26 PM
Quoted: 22 Post(s)
Liked: 59
Adding a new center speaker that doesn't match the other front speakers is of dubious value.
Save up and then replace the front three.
post #6 of 7 Old 09-29-2013, 04:06 PM
gene c353's Avatar
Quoted: 156 Post(s)
Liked: 114
I don't think the quality of Polk speakers has gone down that much if at all. The Monitor series has been around for a few years now.
The P351 and CS10 aren't really direct competetors. The larger CS20 is a better comparison to the P351 and the P250 to the CS10.
In any event, I would prefer the Infinity's but others might prefer the Polks. But you should eventually get the matching front speakers as well.
gene c353 is offline
post #7 of 7 Old 09-29-2013, 07:23 PM
iamwardicus's Avatar
I agree with bladerunner6, save up until you can get a full front 3. If you watch Frys they usually get the Infinity p363 towers for $99 every month to month and 1/2 as a sale. The Center usually goes for $199 I think but not at the same time as the towers. If you can't do towers, I personally own the P163 and it's an awesome little budget speaker.
As for Polk, watch their ebay store and newegg.com.
Also what receiver do you have and what is your current budget (or better yet, if you save up for a bit, your expected budget)? Knowing that will help folks here provide better suggestions for your needs.
iamwardicus is offline
Reply Speakers
Infinity Primus Pc351 Center Speaker , Polk Audio Cs10 Center Channel Speaker Single Cherry
