New guy looking for some bookshelf speaker help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 62 Old 09-29-2013, 04:32 PM - Thread Starter
Chillaxin's Avatar
Hello,
I have been a long time AVSforum viewer, and may I say, thank you everyone for helping us newbies! I thought I would ask for some help before buying speakers.  I'm currently looking for some bookshelves to put together a 5.2 setup.   So far the Sonus Faber sounded the best to me as they had a very warm sound.  Any suggestions to some other speakers I may want to consider? Thanks again!
I got the chance to listen to:
Bowers and WIlkins 685 and CM5
Energy
Martin Logan
Sonus Faber Venere 2.0
Totem Acoustic Model-1
What I already have:
Denon 1908 Receiver
(2) SVS PC12-NSD
Budget - $3500
Room Size: 12'x26'x8'
This is for 100% Movies
Chillaxin is offline
post #2 of 62 Old 09-29-2013, 04:34 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Out of those choices I'd go with the Martin Logans.
NAIM101 is offline
post #3 of 62 Old 09-29-2013, 04:38 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3037 Post(s)
Liked: 2969
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4 of 62 Old 09-29-2013, 04:51 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3079
I would add Focal, Monitor Audio, Ascend Acoustics, and PSB to your list.
In particular,
Monitor Audio RX-2
PSB Imagine B
Focal Chorus 807
Ascend Acoustics Sierra-1 (with NrT upgrade)
Give these a listen if you can. I know you indicated that you preferred a "warm" speaker but the options in this list are worth considering.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #5 of 62 Old 09-29-2013, 05:00 PM - Thread Starter
Chillaxin's Avatar
$1500 just for the bookshelf speakers and then buy the rest that match.  I would consider towers i just like the looks of bookshelf speakers more.
post #6 of 62 Old 09-29-2013, 05:01 PM - Thread Starter
Chillaxin's Avatar
In particular,
Monitor Audio RX-2
PSB Imagine B
Focal Chorus 807
Thank you for the suggestions! I will look around and see if i can audition some of these brands if possible.
post #7 of 62 Old 09-29-2013, 05:09 PM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
Bookshelfs will have trouble filling a room that big. You should get 2 towers for the front.
Licence to Kill
Bond 007 is offline
post #8 of 62 Old 09-29-2013, 05:24 PM - Thread Starter
Chillaxin's Avatar
Originally Posted by Bond 007 View Post
This doesnt make sense to me. Are you wanting to spend $1500 for 5 speakers or 2?
Sorry about that. Total budget for all 5 speakers would be $3500.
post #9 of 62 Old 09-29-2013, 06:04 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2969
I'm using Martin Logan Motion 40's ( for the front L / R ) along with other ML's , and they easily fill a room that size. Looks like you have the subs handled.
post #10 of 62 Old 09-29-2013, 06:36 PM
Bond 007's Avatar
Liked: 1907
No need to get exotic high end speakers for 100% movies imo.
Licence to Kill
Bond 007 is offline
post #11 of 62 Old 09-29-2013, 06:40 PM
Bond 007's Avatar
Liked: 1907
Can you hook up an external amp to your Denon 1908?
Licence to Kill
Bond 007 is offline
post #12 of 62 Old 09-29-2013, 06:42 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
What Energy and Martin Logan speakers are you considering?
2500 cuft isn't all that huge (or is it open to other rooms?). Will you be wall mounting or using stands or? Keep in mind rear ported speakers need some breathing room, sealed can give you more mounting options.
I have Ascend Sierra-1s across the front in a much larger room (that is not totally sealed off from others, altho I can close some doors but a stairwell remains open to the downstairs) and they do just fine. The Sierra-1s (ported) with some Ascend 170SEs (ported) or 200SEs (sealed) would be a good setup (I use both 170SEs and 200SEs in my 7 ch setup). The standard Sierra/170 combo would be $ 1650 shipped, the Sierra/200 combo slightly less; the Sierra upgrade to the NrT tweeters would be an additional $450 ($300/pr). There is also I believe a Raal ribbon tweeter upgrade but not sure of cost or availability on that; there is also a Sierra-2 in the works as well as Sierra Tower/Horizon models. All somewhat within your budgeting depending on options. Ascend is hard to audition unless you're in southern california or have someone near you to let you check theirs out (they're internet direct), but they do offer an in home trial but you pay return shipping.
lovinthehd is offline
post #13 of 62 Old 09-29-2013, 06:43 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Good deal on Focal 807 here
http://www.musicdirect.com/p-139678-focal-chorus-807v-bookshelf-speakers-pr.aspx
And Focal 806
http://www.musicdirect.com/p-139677-focal-chorus-806v-bookshelf-speakers-pr.aspx
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #14 of 62 Old 09-29-2013, 06:43 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
+1 for HT you just need big soundstage and good bass. Martin Logans will do the best room filling with their AMT tweeters. Better than any dome tweeter. If you want warm sound, and since you are going solid state for your amp rather than tubes, just add 1/3 of silver of your whole cabeling (make usre no more than 1/3). It will give you dynamics and a bit bigger soundstage and that warmth.
If you go stereo with $3,500 the door opens up to alot more options. I'd personally go 2.0.
NAIM101 is offline
post #15 of 62 Old 09-29-2013, 07:55 PM - Thread Starter
Chillaxin's Avatar
Thank you for the feedback!  I would use stands with the speakers.  The room is open to a stairwell but i can shut the doors.  I'm not sure i'll get to listen to the Ascend's but I will check them out for sure.
post #16 of 62 Old 09-29-2013, 08:01 PM
Bond 007's Avatar
Liked: 1907
Polk is another good option if you like "warm" speakers and would be a very good choice for home theater.
Licence to Kill
Bond 007 is offline
post #17 of 62 Old 09-29-2013, 08:12 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Another one is KEF R100
http://www.kefdirect.com/r-100-bookshelf.html
Who AM I
zieglj01 is offline
post #18 of 62 Old 09-29-2013, 08:13 PM
Bond 007's Avatar
Liked: 1907
http://www.amazon.com/Polk-Audio-Floorstanding-Speaker-Single/dp/B000V2SEXW/ref=sr_1_5?s=aht&ie=UTF8&qid=1380506552&sr=1-5&keywords=polk+audio+speakers
2 of these for front.
http://www.amazon.com/Polk-Audio-Floorstanding-Speaker-Single/dp/B000V2OQL6/ref=sr_1_3?s=aht&ie=UTF8&qid=1380506781&sr=1-3&keywords=polk+audio+speakers
2 of these for surrounds.
http://www.amazon.com/Polk-Audio-Center-Channel-Speaker/dp/B000V2UBUG/ref=sr_1_8?s=aht&ie=UTF8&qid=1380506875&sr=1-8&keywords=polk+audio+speakers
And this as a center.
This would be an excellent system for both music and movies and would easily fill the room. You can get a better deal on these at the Polk ebay store too.
But for the best performance you will need an external amplifier. Thats why I asked if you can hook one up to your AVR.
Licence to Kill
Bond 007 is offline
post #19 of 62 Old 09-29-2013, 08:16 PM
Bond 007's Avatar
Liked: 1907
Seriously? Would you spend $1200 for that pair of bookshelf speakers for 100% movies in a large room?
Licence to Kill
Bond 007 is offline
post #20 of 62 Old 09-29-2013, 08:20 PM
wadia 9's Avatar
and electrostatic speaker for the dynamics of home theater is a recipe for weakness. Dynamic cones are way better choice for home theater electrostatics are definitely one of the worst way to go for home theater. Not to say they don't sound good they're limited in their dispersion and also limited in their dynamics.
wadia 9 is offline
post #21 of 62 Old 09-29-2013, 08:28 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
OP already has a sub wadia 9. AMT has one of the widest dispersion. It's almost an omnipole design.
NAIM101 is offline
post #22 of 62 Old 09-29-2013, 08:52 PM
Bond 007's Avatar
Liked: 1907
What is "sub wadia 9"? I dont see it mentioned anywhere else here.
Licence to Kill
Bond 007 is offline
post #23 of 62 Old 09-29-2013, 09:08 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Wadia 9 is a user name and I was responding to him. The OP edited post, he has a sub.
NAIM101 is offline
post #24 of 62 Old 09-29-2013, 09:12 PM
Bond 007's Avatar
Liked: 1907
lol Duh..sorry about that.
His post says he has 2 SVS PC12 NSD subs now. Should be plenty for his purpose.
Licence to Kill
Bond 007 is offline
post #25 of 62 Old 09-29-2013, 09:16 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
This is in reference to the OP - and dealer prices can be Lower - also, some movies have a lot of music.
Who AM I
zieglj01 is offline
post #26 of 62 Old 09-29-2013, 09:17 PM
Bond 007's Avatar
Liked: 1907
What center would you recommend with those?
Licence to Kill
Bond 007 is offline
post #27 of 62 Old 09-29-2013, 09:23 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
KEF R-200
http://www.kefdirect.com/r-200-centre-channel.html
Who AM I
zieglj01 is offline
post #28 of 62 Old 09-29-2013, 09:25 PM - Thread Starter
Chillaxin's Avatar
Has anyone heard the SVS Ultra Tower/Bookshelf?  The 45 day free shipping/return is very tempting.
post #29 of 62 Old 09-29-2013, 09:25 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
NAIM101 is offline
post #30 of 62 Old 09-29-2013, 09:27 PM
Bond 007's Avatar
Liked: 1907
Well...one thing for sure. That would put him at his $3500 limit.
Have you heard the Kef R100/200 speakers?
Licence to Kill
Bond 007 is offline
Reply Speakers
Denon Avr 1908 Dolby Digital Surround Receiver
