Troubleshooting a surround speaker - AVS Forum | Home Theater Discussions And Reviews
Old 10-01-2013, 07:34 PM - Thread Starter
ahmedreda's Avatar
Quoted: 301 Post(s)
Liked: 214
I have a 7.2 Polk RTI system: 2 x RTI A9, 4 x RTI A5, CSI A6. All are driven by 2 Emotiva XPA 2/5 and a Denon 4311i as a preamp.
Today while I was watching the Wizard of OZ in 3D, I noticed that my surround left speaker sounds like it has static or crackling that occurs with certain parts of the movie.
I tried to switch the RCA input to the XPA 5 between the left and right speakers and the left speaker still had the issue with the RCA input from the right channel.
I then changed the amplifier channel for that speaker the issue still existed. That tells me it is an issue with either the speaker or the wiring from the amp to the speaker.
This issue did not happen when I tried a more modern movie such as Tron. Could it be possible that it is just an old movie?
If not, how do I proceed from here? Is there something that I can do to pinpoint the source of the problem?
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is offline
Old 10-02-2013, 10:46 AM
Hicks's Avatar
Hmmm well if you heard the static only from that one speaker with both the left and right channel inputs then it is probably not an artifact present on the recording.
If you can connect another speaker to that wire run that will tell you whether it's a problem with the speaker or not.
Hicks is offline
Old 10-03-2013, 10:37 PM - Thread Starter
ahmedreda's Avatar
Quoted: 301 Post(s)
Liked: 214
Thank you, it turned out to be the speaker. It happens only with certain frequencies so it is obvious in some movies more than others.
My home theater
Display: JVC RS400
