20 X 18 room, 12 high - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-03-2013, 02:15 PM - Thread Starter
Eric Leblanc's Avatar
Hi, Im in the process of converting my 20 X 18 garage into a Home Theater, do you guys know if a Denon 5.1 E300 will be sufficient to power up a pair of Polk 703 + a Sub,
Thank you.
Eric Leblanc is offline
post #2 of 3 Old 10-04-2013, 08:36 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Set your speakers to small, XO @ 100Hz, and see.
This may relieve most of the power demand from your AVR since it will then only have to worry about 100Hz-20kHz, which requires a lot less power.
AcuDefTechGuy is offline
post #3 of 3 Old 10-05-2013, 04:40 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
If you are going to go thru the steps of converting a garage into a theater, then I don't think you should get that AVR. You may like it for awhile, but you will be looking to upgrade before you gotten your money worth out of it. That will be a nice size room, and you may want to go 7.1 or maybe 9.1. You will may also want to add an amp later and you cannot with that AVR.
HAMP568 is offline
Reply Speakers
Denon Avr E300 , Polk Audio Lsi M703 Bookshelf Speakers Midnight Mahogany Each
