Looking for Good Efficient Speakers for New Teac Micro System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-05-2013, 12:44 PM - Thread Starter
RDSChicago's Avatar
Hi, I just purchased the TEAC H01.3-B Digital Streaming Micro System at Accessories4 Less for a very good price. The specs and DAC that come with it sounded extremely good especially for the system's price of $429. Although it comes with Teach's own speakers, I am looking for good, efficient speakers that would match the amp, which is rated on Teac's website with the following specs:
Output Power: 50W + 50W (4 ohms, 20 – 40,000 Hz, 1% THD) 22W + 22W (8 ohms, 20 – 40,000Hz, 1% THD)
Would this amp be powerful enough to drive Kef LS50's, or the Kef R100's? What other speakers would sound good with this setup? I will use this in an office environment exclusively for music.
RDSChicago is offline
post #2 of 16 Old 10-05-2013, 02:20 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I take it in an office environment you aren't going to get very loud, right? Pretty much most speakers will be fine I would think but if you want to push to very loud levels then a higher sensitivity rating would be a good thing with that amp.....what are the sensitivity specs for those speakers?
ps I somewhat doubt that amp is really capable of much at 4ohm, though...
lovinthehd is offline
post #3 of 16 Old 10-05-2013, 02:31 PM - Thread Starter
RDSChicago's Avatar
85 and 86 db for LS50 and R100, respectively
post #4 of 16 Old 10-05-2013, 02:34 PM
lovinthehd's Avatar
Liked: 4775
What impedance? (yes, I'm too lazy to look it up) smile.gif How loud do you want to listen?
post #5 of 16 Old 10-05-2013, 02:47 PM - Thread Starter
RDSChicago's Avatar
Both 8 ohms
post #6 of 16 Old 10-05-2013, 03:24 PM
lovinthehd's Avatar
Liked: 4775
So at 1w/1m you're going to get 85/86 dB, 2w 88/89, 4w 91/92, 8w 94/95, 16w 97/98, 32w 100/101...do you need more spl than that? Unless you work at home hard to imagine needing more...
post #7 of 16 Old 10-05-2013, 03:30 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
For a office, almost any good speaker should work -
audition and find the sound you like.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #8 of 16 Old 10-05-2013, 04:12 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Budget?
bladerunner6 is offline
post #9 of 16 Old 10-05-2013, 04:14 PM - Thread Starter
RDSChicago's Avatar
$500-$1,000. What about Zu Audio?
post #10 of 16 Old 10-05-2013, 04:29 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
What have you listened to, or owned in the past - what type of sound do you like?
Also how big is your office, and how far will you sit from the speakers?
Who AM I
zieglj01 is offline
post #11 of 16 Old 10-05-2013, 08:38 PM - Thread Starter
RDSChicago's Avatar
I will sit around ten feet from the speakers if all goes as planned. This is my first two channel setup. Thanks.
post #12 of 16 Old 10-05-2013, 08:49 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Along with KEF
Take a look at Focal - good closeout pricing
http://www.musicdirect.com/p-139677-focal-chorus-806v-bookshelf-speakers-pr.aspx
Who AM I
zieglj01 is offline
post #13 of 16 Old 10-07-2013, 07:25 PM
Quoted: 911 Post(s)
Liked: 490
The amp module in that Teac integrated - ICEpower 50ASX2 - is deceptively powerful, IMO. For a time I drove KEF Q100's with it and could fill the next room over. It'll be fine with R100's or LS50's. (I sold the Teac amp because the remote stupidly does not have an on/off button.)
Not in the same league.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #14 of 16 Old 10-07-2013, 10:42 PM - Thread Starter
RDSChicago's Avatar
Thank you for the replies. Are you sure this amp could drive LS50's? I was told I needed at least 75 watts per channel to even begin to drive this speaker adequately.
post #15 of 16 Old 10-07-2013, 11:01 PM
lovinthehd's Avatar
Liked: 4775
post #16 of 16 Old 10-08-2013, 06:01 PM
Quoted: 911 Post(s)
Liked: 490
Thank you for the replies. Are you sure this amp could drive LS50's?.
Yes. In the material and relevant aspects to that question (speaker efficiency, impedance curve) the Q100 and LS50 do not materially differ, and that Icepower module is fine to drive the Q100s. Especially in an office.
Serious Audio Blog
DS-21 is offline
Reply Speakers
