Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-08-2013, 06:46 PM - Thread Starter
Donzy's Avatar
Hi There, I could really do with your advice, I have a theatre room which is about 6.5 metre by 5.5 metres, I have powerful old but good JBL front speakers, Boston rears and jbl centre speaker with a new yamaha rxv2075 receiver. I need a subwoofer and am so confused. It was suggested either a definitive super cube 6000 or maybe a a paradigm ultra cube 12 inch. We will be using it for movies, not music. Any suggestions? I was looking at spending obviously the least I can but about $1000. Thanks in advance. smile.gif
Donzy is offline
post #2 of 9 Old 10-08-2013, 07:02 PM
Audiophile2k's Avatar
Liked: 46
You should check out the subwoofer subsection of the forum. Since you are posting in meters, I assume you are not in the US. Typically internet direct companies will give you a lot more for your money than the ones you are considering, but we would need to know your location to find out what is available where you are.
Audiophile2k is offline
post #3 of 9 Old 10-08-2013, 07:05 PM - Thread Starter
Donzy's Avatar
Thank you for your reply, yes I'm from Australia, however am prepared to buy online. I have read so many reviews, my heads spinning.
Donzy is offline
post #4 of 9 Old 10-08-2013, 07:19 PM
Liked: 46
The problem is subs are big and heavy, and therefore expensive to ship. I'll list the frontrunners here in the states, and leave it up to you to find out what can be shipped and for how much. My personal favorite is Rythmik, because I really like tight, controlled bass that sealed servo systems offer. But others to consider are HSU, PSA, SVS, and Outlaw. I might have left someone out...but as I said, post in the Subwoofer section, and list your room dimensions and listening preferences, since that matters a lot with subs. Be sure to mention your location also...maybe you'll be lucky and a fellow Aussie member will have some inside knowledge.
post #5 of 9 Old 10-08-2013, 07:50 PM - Thread Starter
Donzy's Avatar
Thank you for that info. Yes some shipping costs are $650 crazy and understandable given the weight. We will be using the sub for movies and theatre. I will keep researching. The room is about 6.5 metre by 5.5 metres. I may have to buy from Australia ouch. One sub is $1800 here can get is for just under $1500 and in USA it's $800, crazy how we get ripped off.
Donzy is offline
post #6 of 9 Old 10-08-2013, 07:52 PM
Valtyr's Avatar
Liked: 80
Well, I'd recommend SVS PB1000 x2 if you can get it shipped there, they ship to the states for free.
HSU has the VTF3 that would work well.
Rythmik has one for $589
Just try to find the best deal, but please don't get any sub but an internet direct brand!
Valtyr is offline
post #7 of 9 Old 10-08-2013, 09:20 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
SVS Audio has an Australian distributor. Check the international sales section of their website.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #8 of 9 Old 10-08-2013, 09:29 PM
A9X-308's Avatar
Quoted: 1306 Post(s)
Liked: 966
That's why a lot of us down here DIY our subs; more performance for less money, and a sub is the easiest enclosure of all to build.
You could buy a Mach 5 UXL18, a MiniDSP for EQ and HPF/LPF and a Behringer NU3000, measurement mic preamp etc for less than $A1800. One will give about twice the volume displacement of an SVS PB13U, and you can use the amp to power two, so you could add another later.
A9X-308 is offline
post #9 of 9 Old 10-08-2013, 11:09 PM
K1LL3M's Avatar
For the price point you are chasing buying OS just isn't worth it as you kill your value in freight.
Couple of options to look at is
1. Check out Eastwood hifi specials page
http://www.eastwoodhifi.com.au/specials.html Great company and one of the largest local hifi online sales folks in volume.
2. Talk to Peter at DeepHz (Australian SVS retailer) http://www.deephzaudio.com Peter is truly a great bloke and he maybe able to work something out with you.
3. Check out the DTV Forums, and post there. http://www.dtvforum.info Often killer 2nd hand bargins show up there or the guys there no where there is a bargin happening.
Cheers
K
K1LL3M is offline
Reply Speakers
