Lowest gauge that works on Bose acoustimass 10 cube speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-09-2013, 06:42 AM - Thread Starter
delt31's Avatar
Quoted: 85 Post(s)
I have the acosutimass 10 system with the cube speakers and I need to buy speaker wire for the backs. Does anyone know if 14 gauge would work? I called Bose and they mentioned 18 but that seems fairly thin and I believe their inwire adaptor accepts 14 or higher. Does anyone have any experience with these?
Also - best place to buy wire from retail stores? I don't have time to get from monoprice as I need this today.
And please, no why bose, bose sucks, etc. Thanks.
delt31 is offline
post #2 of 7 Old 10-09-2013, 06:48 AM
Bill Fitzmaurice's Avatar
Liked: 4628
Use this:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
Bill Fitzmaurice is online now
post #3 of 7 Old 10-09-2013, 07:15 AM - Thread Starter
delt31's Avatar
Quoted: 85 Post(s)
thanks but I'm trying to determine if the thinkness of 14 gauge is too big to even put into the back of the bose cube speaker.
delt31 is offline
post #4 of 7 Old 10-09-2013, 07:16 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Take some 14 ga lamp cord and pull off the jacket. You'll see a bunch of very thin individual strands of wire. Then separate out a single strand of wire from the rest of the strand bunch. That should be enough for what you need.tongue.gif
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #5 of 7 Old 10-09-2013, 09:56 AM - Thread Starter
delt31's Avatar
Quoted: 85 Post(s)
serious answers would be great
delt31 is offline
post #6 of 7 Old 10-09-2013, 10:22 AM
Elihawk's Avatar
Quoted: 1013 Post(s)
Liked: 854
Since most of the people on this forum don't care much for Bose, most don't own them. So really, to know if 14g wire will work with your cube you probably just have to try it! If Bose says 18, then just use 18. If it sounds like crap, it won't be due to the gage of the wire!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #7 of 7 Old 10-09-2013, 08:34 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Aw come on! That was funny! If Bose supplies 18 gauge, then there isn't really any reason to go with a thicker gauge.
Reply Speakers
Bose Acoustimass 10 Series Iv Home Entertainment Speaker System Black
