Help with Klipsch setup for media room. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 48 Old 10-13-2013, 04:31 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
Originally Posted by Dr Feltersnatch View Post
my buddy has a classè setup that is amazing. he told me to find a used ssp-600 or something like that. says it sounds great but is just missing hdmi switching.
Bad idea. Think of it as audio jewelry. The Denon that was recommended above will sound exactly the same and provide better functionality.
FMW is offline
post #32 of 48 Old 10-13-2013, 05:40 AM
GIEGAR's Avatar
Quoted: 783 Post(s)
Liked: 1332
Originally Posted by Bond 007 View Post
If you post a flexible budget here you will get $20,000 suggestions. You need to set some kind of realistic cap.
um.. figure 5-6k budget.
Firstly, I suggest you flick the idea of the second-hand Classé. There is much better value in current AVR's with modern A/V processing and solid room EQ routines. Today, the quality of the room EQ routine is the single biggest influence on the sound quality of the processor/AVR, and the best of these routines currently available in a consumer AVR is widely regarded to be Audyssey MultEQ XT32 (with Sub EQ HT).
The cheapest XT32 enabled AVR is currently the Denon AVR-X4000, which can be found for around $1200 (Crutchfield open box; or call AVS Sales own jdsmoothie and twist his arm for their best new price). This equates to 20% of a $6K spend, which is towards the limit of what's regarded as reasonable budget split.
My recommendation for a great high performance front end plus subs that fits your budget is one from Ascend Acoustics/Rythmik Audio. I believe these speakers offer performance at least on a par with the Paradigms you mentioned at a very reasonable price.
So, in summary:
Main L & R: Ascend Sierra Tower pair ... $1900
Centre: Ascend Sierra Horizon ............. $1000
Subs: Dual Rythmik Audio F15 ............. $1950
Less: Discounts on above ................... $220
AVR: Denon AVR-X4000 ..................... $1170
TOTAL (ex. shipping) ........................... $5800
If you can figure out a way to accommodate surround speakers in your room, that would be highly desirable. In that case suitable surrounds are Ascend CBM-170 SE's (ported; away from walls) or HTM-200 SE's (sealed; near or on-wall).
GIEGAR is offline
post #33 of 48 Old 10-13-2013, 07:01 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Originally Posted by NAIM101 View Post
If its a 6k budget I highly recommend this.
Pair of Selah Verita for $2,500 delivered.
You will get this kind of sound but better because this video is not using a RAAL tweeter but a Job 225 type amp.
This video is with Selah Verita but with Emotiva amps. (Job is 20x better in performance lesser price). Check out how the Verita and the RAAL tweeter and how clear it is. You can hear the breathing of the singer loud and clear.
I know the Youtube Videos does not do them justice, but hompefully you can hear that the sound is very clear, real, and good soundstage.
You will never get this quality of sound from those klipsch's + HK LOL.
Are you for real? You want him to judge the clarity of a tweeter and the soundstage of loudspeakers from youtube videos played back on his computer speakers? And you finish your post with an LOL?
psgcdn is offline
post #34 of 48 Old 10-13-2013, 12:22 PM
NAIM101's Avatar
Quoted: 348 Post(s)
Liked: 45
Since Amps dont make a difference to sound, I suppose DAC's dont make a differece to sound, and Oppo is ripping everyone off from 103 to 105 adding $600.00 just for the Sabre DAC on analog audio which the 103 dont have..
And no its not really a placebo effect either. nobody in their right mind would spend $2,000 - $5,000 on a Amp over a $400 AVR which has the convienience if they dont hear a sonic difference. They would just sell their old speakers and just spend the money on new speakers.
NAIM101 is offline
post #35 of 48 Old 10-13-2013, 03:09 PM
GIEGAR's Avatar
Quoted: 783 Post(s)
Liked: 1332
^ This is a crude attempt to highjack the thread. ^
NAIM101: STOP IT!
If you want to have this debate, have some respect for the OP and start your own thread.
laulau and ien2 like this.
GIEGAR is offline
post #36 of 48 Old 10-13-2013, 06:02 PM
MUDCAT45's Avatar
Quoted: 389 Post(s)
Liked: 289
You finally got something right.
MUDCAT45 is offline
post #37 of 48 Old 10-13-2013, 09:58 PM
blake18's Avatar
Quoted: 315 Post(s)
Liked: 191
MUDACAT45, I gotta disagree with you there, I think there is a HUGE difference in amp quality depending on price. I am personally using Denon's older avr 5600 flagship $4000 receiver and it BLOWS AWAY my newer Onkyo tx-sr705, which weighs only 29lbs compared to the Denon that weighs 54lbs. The weight difference translates to a HUGE difference in sound.
I am using all Klipsch Reference RF-3II set-up.
Lumenlab "Community driven video lab".
blake18 is offline
post #38 of 48 Old 10-14-2013, 05:50 AM
MUDCAT45's Avatar
Quoted: 389 Post(s)
Liked: 289
How are you defining quality? Do you mean longevity/durability or quality of sound?
You are not only hearing different amps but different processors when comparing your AVR's. How do you know which is responsible for the difference in sound?
Comparing the amp in a $400 AVR to a $5000 amp may not be in order. However, IMO, there will be more change with different speakers than with an amp.
MUDCAT45 is offline
post #39 of 48 Old 10-14-2013, 08:31 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
The OP has a 5-6 K$ budget, so please don't derail it with talk of $2,000 - $5,000 amplifiers or $4000 receivers. There are plenty of other threads for that.
psgcdn is offline
post #40 of 48 Old 10-14-2013, 09:52 AM
FMZ
FMZ's Avatar
Onkyo TX-818 is the cheapest XT32 receiver out there. I think the only problem with their implementation is that they dont EQ the subwoofer or the 2nd subwoofer (Not sure which one is correct).
Also, their quality is questionable (HDMI board frying itself issues reported).
http://www.amazon.com/Onkyo-TX-NR818-7-2-Channel-Network-Receiver/dp/B007JOO4XE/ref=sr_1_1?ie=UTF8&qid=1381769376&sr=8-1&keywords=onkyo+818
FMZ is offline
post #41 of 48 Old 10-14-2013, 09:56 AM
Transmaniacon's Avatar
Quoted: 1582 Post(s)
Liked: 1381
All versions of Audyssey MultEQ will EQ a subwoofer. As far as I know, SubEQ HT is part of XT32 and yes will EQ two subwoofers.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #42 of 48 Old 10-14-2013, 11:57 AM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
It is not and 818 doesn't set independent distances for dual subs.
SanchoPanza likes this.
Kisakuku is offline
post #43 of 48 Old 10-14-2013, 11:59 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
^^^correct
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #44 of 48 Old 10-14-2013, 12:13 PM
Liked: 1381
Their website is incorrect then;
http://www.audyssey.com/news/audyssey-multiple-subwoofer-eq-technology-now-avrs
Audyssey Sub EQ HT is currently in every AVR that uses MultEQ XT32. These models can be found on our website www.audyssey.com.
More reason to get the Denon AVR-X4000.
post #45 of 48 Old 10-14-2013, 03:11 PM
GIEGAR's Avatar
Quoted: 783 Post(s)
Liked: 1332
Yes, you are correct; the Onkyo 818 is currently the cheapest XT32 enabled AVR. What I should have said is that the Denon X4000 is currently the cheapest XT32 enabled AVR with full implementation of Sub EQ HT that properly sets up and EQ's two independent subs.
I am also reluctant to recommend the Onkyo 818 because of lingering doubts over HDMI board reliability that you mention.
The key word is "currently". At August 2010, that statement was probably correct as the Onkyo 818 was yet to be released. The AVR Audyssey MultEQ FAQ explains the distinction with the Onkyo 818.
Transmaniacon likes this.
GIEGAR is offline
post #46 of 48 Old 10-14-2013, 03:21 PM
FMW
FMW's Avatar
Liked: 1686
Originally Posted by Reference_head View Post
If your 2.0 is good you won't even want 5.1???? What does that even mean?
5.1 is the whole point of ht. take away all those channels and your left with a 2ch set up. Nothing wrong with 2ch but it can't touch a good multi channel set up for movies. Saying surrounds don't do that much is really bad advise.
He's not here to give good advice. He's here to troll and draw attention to himself. He's been doing it on all the forums. Best ignore him and he'll eventually moves elsewhere.
FMW is offline
post #47 of 48 Old 10-14-2013, 07:02 PM
dlozy's Avatar
Quoted: 12 Post(s)
Liked: 25
I would agree 800 would be better spent on other things for sure. Keep in mind the rc-64ii will cost around $900 (paid around 700 for mine) and the rc-62ii will be around $400 give or take $50. I realize retail is 850 more but street price is much less. biggrin.gif
I was responding to your post that its only a little better which is not true imo.
Reference Head, do you mind me asking where you found the rc-64ii for that cheap? I'm looking to buy one, but $1100 is the cheapest I've seen them at.
dlozy is offline
post #48 of 48 Old 10-15-2013, 02:12 AM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Acoustic sound design sells most of the reference line 30% off retail. You have to call them for prices and talk to mike. When I got mine retail was 1200 then they changed it to 1400 a few months later. My friend worked at ultimate and he always got me stuff around 55-60%. Also call here at Avs for a price quote and see who is cheaper.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
Reply Speakers
Klipsch , Klipsch Audio
