recommendations on new DefTech system??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-10-2013, 10:53 AM - Thread Starter
nycguy718's Avatar
I am new here but I think I have decided to go with DefTech for my system. First I was sold on the ProCinema and hang the speakers on the wall but after doing more research I m thinking about the BP-8040 Speakers.Would there be a big difference between these 2 setups?
setup 1 = Denon AVR-33213CI with DefTech ProCinema 1000
or
setup2 = Denon AVR-3313CI with  2= BP8040ST , CS-8060HD , 2= SR-8080BP
I will be mostly watching movies and using Airplay to listen to Itunes music. I live in a 2 bedroom apartment and my MAIN goal is to get the wow factor from clear and crisp speakers not just loud. Is setup 2 overboard for an apartment? anything you would do to make this better?
Opinions would be appreciated
nycguy718 is offline
post #2 of 12 Old 10-10-2013, 10:57 AM
Brad Sutliff's Avatar
if your not going to use a sub with setup 2 i would go with setup one. youll have better bass response and cheaper
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #3 of 12 Old 10-10-2013, 11:05 AM - Thread Starter
nycguy718's Avatar
Brad the bp8040 come with built in subs.. might now be best but are the bp8040 better speakers?
post #4 of 12 Old 10-10-2013, 11:23 AM
I would say they are better, i like the effect from BP front speakers, create a wider soundstage. However in my opinion separate dedicated subs will always be better than built in subs. But with the apartment in mind the floorstanding might be a better option.
post #5 of 12 Old 10-10-2013, 01:03 PM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
The built-in "subs" do not go nearly as low as a modestly priced ID sub. the bipolar speakers are much nicer speakers than the pro-cinema. In addition to the bi-polar sound quality, they also have the newer generation of drivers so it should give you clearer midrange and treble. I would go for the BP set-up and get an ID sub to round out the system (or at least save to get one in the future).
nycguy718 likes this.
simp1yamazn is offline
post #6 of 12 Old 10-10-2013, 01:14 PM - Thread Starter
nycguy718's Avatar
budget is an issue lol i have a little one coming in 40 days so.. lol i can get by with the BP speakers and then get the sub for Xmas.
post #7 of 12 Old 10-10-2013, 01:16 PM
Quoted: 109 Post(s)
Liked: 77
good idea, and congratulations!!!
post #8 of 12 Old 10-10-2013, 01:59 PM
Congrats! Your going to love def. Tech. I know I love mine
post #9 of 12 Old 10-10-2013, 02:43 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1293
You could always split the difference and go with the new SM series like the 55 or 65 AND a good ID sub for about the same price as option 2. It would give you the updated drivers (newer than the BP series) and better bass response.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #10 of 12 Old 10-10-2013, 03:45 PM
Elihawk's Avatar
Quoted: 1013 Post(s)
Liked: 854
If budget is an issue...you can get a great deal on the SM350/450s as they are about to be discontinued. Now, finding the matching center (CLR2002) can be a bear, so if you wnet this route, you could use them as surreound and upgrade to bigger speakers for the front later. I own the SM450s and those are one nice speaker, especially for the essentiall 200/pr I paid!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #11 of 12 Old 10-11-2013, 07:24 AM - Thread Starter
nycguy718's Avatar
so you would get 4 X SM65 and a good sub over my option 2? I thought the BP speakers are better than the SM based on reviews?
post #12 of 12 Old 10-11-2013, 07:49 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I used to own all Definitive Tech speakers, and I do think they sound great.
But I would also recommend getting bookshelf speakers + multiple subs whether it is DEF TECH or any other brand.
But what are all the speakers you have heard?
You want to hear all the other brands before finalizing no matter what brand you end up buying.
AcuDefTechGuy is offline
Reply Speakers
