Rear Speaker advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-10-2013, 04:55 PM - Thread Starter
coldsteel333's Avatar
I have Andrew Jones towers and center and am looking to add some rear speakers. I know most will suggest the Andrew jones bookshelfs, but they are just to big and gaudy to wall mount. Need something small with good sound match to the L/C/R. Need to keep it under 200 for the pair.
coldsteel333 is offline
post #2 of 7 Old 10-10-2013, 05:08 PM
hdnewbie21's Avatar
Liked: 38
They can't (shouldn't) be wall mounted as they are rear ported.
I'm not sure how well they'll match, but here is an option for wall mounted http://www.amazon.com/Klipsch-Synergy-S-10-Surround-Speakers/dp/B003XRD9VE/ref=sr_1_4?s=aht&ie=UTF8&qid=1381449947&sr=1-4&keywords=klipsch
They are small enough and less than $200. If they don't match well, you can return them.
Yamaha RX-V673 | HSU HC-1 MK2 | HSU HB-1 MK2 - LR | Pioneer SP-BS22-SLR | BIC RtR-V44-2 (Presence)
hdnewbie21 is offline
post #3 of 7 Old 10-10-2013, 08:00 PM - Thread Starter
Anywhere local have those or just Amazon?
post #4 of 7 Old 10-10-2013, 08:19 PM
swim33's Avatar
swim33 is offline
post #5 of 7 Old 10-10-2013, 08:49 PM
Brad Sutliff's Avatar
I bought the s10s from klipsch a week ago for rears. I love them. I highly reccomend them. I got them for 150.
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #6 of 7 Old 10-11-2013, 06:03 AM - Thread Starter
What are your front speakers?
post #7 of 7 Old 10-11-2013, 07:47 AM
I'm in the middle of upgrading. But they are def tech studio 45s
Reply Speakers
