Surround choices - too high, too wide, or too far back. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-11-2013, 10:09 PM - Thread Starter
Glenn_Law's Avatar
I'm trying to place surrounds in my theater room. The room layout puts a set of double doors right where I need to put my right surround speaker. The room is 13x16. I've placed the screen on the 13' wall that is farthest from the doors (the builder pre-wired for putting the screen on the 16' wall opposite the doors. I rotated the configuration by 90 degrees because I want two rows of seats). There are double doors on one of the 16' walls, at one end of the wall. I'm putting in two rows of seats - the front row will be about 10' from the screen, and the back row will be against the back wall (such that the double doors will be to the right of the people sitting in the back row)
My surrounds either have to go (a) forward of the doors, which would put them directly to the side of the front row, but too far forward for the back row; (b) on the back wall, which would be too far back for the front row (they would be like 7.1 rear speakers); or (c) above the 7' doors, which puts them above optimal height. I'm leaning towards option (c) which will put them too high. Any thoughts on which would give me the best sound?
This image shows the floor plan:
This image is looking at the back wall.
Glenn
Glenn_Law is offline
post #2 of 7 Old 10-11-2013, 10:44 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2900
For a 5.1-speaker layout, I would put the surrounds in the back corners of the room, at least a couple of feet above ear level, pointing towards the main listening position (middle of front row).
However, with your main seating away from the back wall, you are an ideal candidate for a 7.1 layout. Put the side speakers directly to the sides of the front row and the rear speakers above the sconces on the back wall. Again, all four surrounds mounted at least a couple of feet above ear level.
This will give you excellent rear-vs-side separation and wrap-around envelopment in the surround field.
Sanjay
sdurani is offline
post #3 of 7 Old 10-12-2013, 04:05 PM - Thread Starter
Glenn_Law's Avatar
Thanks. I've been thinking about doing the 7.1 thing. The only thing stopping me is that the rear speakers will be right over the back row. OTOH, the back row probably won't get used much anyway.
post #4 of 7 Old 10-12-2013, 05:44 PM
sdurani's Avatar
Liked: 2900
But the speakers will be pointing forward, not at the listeners in the back row, so it won't be distracting for them. Imagine holding a bookshelf speaker above your head: you won't hear it as loudly as the person you're pointing the speaker at.
Sanjay
sdurani is offline
post #5 of 7 Old 10-15-2013, 03:27 PM - Thread Starter
Glenn_Law's Avatar
It would be nice to have a 7.1 and not have a speaker in the corner. I can always put it back if the rear speakers don't sound right from the back row.
post #6 of 7 Old 10-15-2013, 03:36 PM
imcloud's Avatar
Quoted: 18 Post(s)
I would play with a few different surrounds, bi di pole booshelfs, I tried 5 different pairs before choosing the bookshelfs I have now, but in some rooms an inexpensive bipole works wonders, especially when mounting is optimal...  My bookshelfs are mounted on the ceiling at a slight downward angle, about 3 feet over the listener and a foot outside, but its 1 row of seating... They sound fine, but admittingly better when I had them on stands on the sides of the listener, but the wife didn't approve so to the ceiling they went...
I hate to say it but this is one of them things that I think needs to be tested, different speakers, different positions, and make a decision...
Geoff4RFC likes this.
HT-Emotiva UMC200 and XPA5, Ascend 340se front stage, 200se surrounds, Dual HSU VTF2's
Bedroom music-jolida 202 integrated & Tekton Lores
Formal parlor music- XPA2 & XDA2, Wharfedale Evo2-40's, dual WD sw subs, pure i20
Guest parlor-Parasound 2100 outlaw 2200 monos, csb1 bookshelfs, dual SVS sb12nsd subs
imcloud is offline
post #7 of 7 Old 10-15-2013, 10:56 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
This sounds good. Bi/Dipole speakers give you flexibility. Here's a couple of links that might help out as well.
http://www.polkaudio.com/polk-university/articles/home-audio-speaker-placement
http://www.polkaudio.com/polk-university/technology/bipole-dipole-surround-sound-control
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Reply Speakers
