Klipsch RF82 mk2 - Bass is very weak & thin - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 10-12-2013, 02:50 AM - Thread Starter
SL77's Avatar
Hi ,
I have RF-82 mk2 connected to Pioneer SC-37 and I'm afraid that I don't have enough power when I Listen to music in pure direct mode.
The bass is very weak like a small speaker. In movies the subwoofer help them and its
Difficult to hear who speaker give the bass.
Any suggestions ?
SL77 is offline
post #2 of 26 Old 10-12-2013, 07:54 AM
Brad Sutliff's Avatar
Your receiver should have plenty of power to make those things rock. Have you ran mcacc with them? It might have set the levels for them super low
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #3 of 26 Old 10-12-2013, 08:04 AM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Originally Posted by SL77 View Post
Hi ,
Any suggestions ?
pure direct mode wont have any eq. I would run in direct mode (not pure) and eq the bass up to what you like.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #4 of 26 Old 10-14-2013, 05:37 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
Hi ,
Any suggestions ?
Check in your speaker setup, the fronts should be set to "large" if you are not using a sub.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #5 of 26 Old 10-16-2013, 10:08 AM - Thread Starter
SL77's Avatar
Thanks for the replay guys.
My front are set to large , center to small and rears small also.
My setup -
RF 82 fronts
Rc-62 center
Monitor audio dipole rears
Paradigm pw- 2200 subwoofer
My sub cross to 80hz.
As you suggested , I try to hear in direct mode ( not pure ) with equalizer on and it's not
Enough like I think it should be...
SL77 is offline
post #6 of 26 Old 10-16-2013, 12:24 PM
Liked: 1394
Check the polarity of your wires, red to red and black to black.
post #7 of 26 Old 10-19-2013, 01:04 AM
qpvh79's Avatar
Having the same problem with my RF82s and Pio VSX-1120k. My speakers don't seem to be hitting 80Hz, even when set to Large. If anything, these towers sound more like satellites, with a frequency gap between them and the sub. And speaking of the sub (SVS PB12-NSD), it seems to be getting a very weak signal--I really have to crank the gain to hear it. MCAAC just makes things sound even worse. I don't know if it's the room, the AVR lacking power to drive larger speakers, or the AVR just being faulty. Really, the system kind of sounds like a Logitech 5.1 PC speaker at this point. eek.gif
Going to test it with a friend's Marantz, which has a 650w max power draw (vs 400w for my Pioneer)
qpvh79 is offline
post #8 of 26 Old 10-19-2013, 03:52 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
My setup -
RF 82 fronts
Rc-62 center
How big is your room? Are you setting large and using a sub? If so, there might be a phase issues with the sub and the fronts. If you are using a sub, try setting your fronts to small, and play with you distance settings for the sub. Also, check speaker polarities and make sure your sub is connected to sub out.
Another suggestions is to walk around the room to see if there would be another spot where the bass is strong. If so, then your current spot might have a room mode with a null.
RicardoJoa is offline
post #9 of 26 Old 12-12-2013, 05:36 AM
RMZguy151's Avatar
I am having the same issue with my RF-82II. If I am running direct on my Marantz SR7007 listening to music the bass is less than impressive out of these RF-82II. Ive seen videos of the drivers bouncing on the 82's with about the same setup that I have. What should I do?
Klipsch RF-82II Floors
Klipsch RC-62II Center
Klipsch RS-42II Surrounds
SVS PB12-NSD Sub
Marantz SR7010 Receiver
2016 Vizio P65-C1
RMZguy151 is offline
post #10 of 26 Old 12-12-2013, 06:04 AM
PM-Performance's Avatar
Quoted: 255 Post(s)
Liked: 146
How far you guys have these off the walls?
I am feeding pretty low power to mine and they sound very full when in full range mode. Mine do not flop around like they show in the videos you probably seen but they do kick some ass in two channel
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
post #11 of 26 Old 12-12-2013, 06:22 AM
RMZguy151's Avatar
I have to turn my volume up so high in order to get decent bass out of them. I have them about 8-10" off the wall. Do you have your fronts set to large? When I change my sound from direct to my 5 channel and it activates the center channel speaker, It sounds like my Rc-62II center channel hits harder than my RF-82's. Not sure whats up
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #12 of 26 Old 12-12-2013, 06:26 AM
Quoted: 255 Post(s)
Liked: 146
Yes I set mine to full range when in two channel. I do not use direct or pure though. Do you have them toed or straight on?
Have you had other towers in place before that performed better?
post #13 of 26 Old 12-12-2013, 06:53 AM
RMZguy151's Avatar
I have them toed in slightly, I had a pair of Klipsch VF-36 in their place before, I can't remember what they sounded like. I don't normally listen to music on that system. It is mainly for Movies and some gaming. I guess I was just less than impressed when I decided to play some music through the system. Do you keep the "gold" terminal connectors that go from positive terminals and also negative terminals in the back of the RF-82's? Would that make any difference.
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #14 of 26 Old 12-12-2013, 07:02 AM
Zen Traveler's Avatar
Quoted: 585 Post(s)
Liked: 597
I dunno....I don't like using my RF-7s alone for 2 channel music and when I engage the subs on this material it sounds awesome. On the Denon AVRs there is a way to set the Bass Mgmt in 2 Channel mode to "LFE + Mains" and in direct mode I can still use the sub on this source while leaving the Multichannel Configuration set to only LFE in BM.
Zen Traveler is offline
post #15 of 26 Old 12-12-2013, 07:22 AM
flickhtguru's Avatar
Liked: 111
YES you MUST keep the gold binding straps connected UNLESS you bi amp or bi wire. If you disconnect them and only hook up to the top set you are only feeding the horn tweeter with power.
Shawn
flickhtguru is offline
post #16 of 26 Old 12-12-2013, 08:01 AM
RMZguy151's Avatar
I can make the same changes on my Marantz AVR but I guess I am just expecting more out of the floorstanders. I wish I could hear another set up with the same speakers and different AVR to see if its settings on the AVR or something else. I guess I'm just thinking for the size of the speakers, I should be getting more full range sound, the mids and the highs sound pretty good.
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #17 of 26 Old 12-12-2013, 08:03 AM
RMZguy151's Avatar
I have them bi-wired
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #18 of 26 Old 12-12-2013, 08:17 AM
Quoted: 585 Post(s)
Liked: 597
I would put the connectors back on and run one set of wires...It may not alleviate what you are experiencing but imo, Klipsch puts dual binding posts in the back of their Reference Speakers because their investors have a stake in Copper. wink.gif Good Luck.
post #19 of 26 Old 12-12-2013, 08:25 AM
Liked: 111
^^^+1
AFAIK bi-wiring does absolutely nothing except uses more wire. There is even debate on if bi-amping does anything cuz the tweeter draws very little power so it doesn't take much power from the woofers when wired standard.
Shawn
post #20 of 26 Old 12-12-2013, 08:31 AM
Kini62's Avatar
Quoted: 1746 Post(s)
Liked: 1558
My 62s have pretty impressive bass run full range. They are in a smallish room though. 1650^3
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #21 of 26 Old 12-12-2013, 08:42 AM
Quoted: 585 Post(s)
Liked: 597
No doubt...It all depends what you are comparing it to. Paired with a capable sub I still think they should be run as Small, with a crossover set to get full benefit from a SQ point of view.
post #22 of 26 Old 12-12-2013, 08:43 AM
Quoted: 255 Post(s)
Liked: 146
If you don't keep those in, you are not running all your drivers.
You would only take those out if biamping. And even if so is a negligible task to even do.
I think one post is for the horns and other is for drivers but nonetheless if not hooked up out the jumpers back in and rerun audessy
Again the 82's should sound pretty full without a sub. I prefer without a sub for music. I think the sub over does it. And I am a bass head.
I guess just don't expect floor shaking bass from the towers. I played some dub step one day to test the bass from mine and I thought they were more than impressive from a smaller tower.
post #23 of 26 Old 12-12-2013, 09:49 AM
RMZguy151's Avatar
This is what I'm talking about, I also have seen some 62's that are impressive. My room is only about 1700 sq/ft but does have 2 openings to hallways. I'm gonna go home and mess around with it some, I need somebody here that knows their **** and can go through the settings on my AVR. Confused!!!
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #24 of 26 Old 12-12-2013, 11:00 AM
RMZguy151's Avatar
I would rather not have the sub playing when listening to music also. I would think that with the quality sound out of the Marantz I would have no trouble getting big full spectrum sound out of the big floor standers. I'm not expecting flor shaking bass just really nice full sound. Can anybody think of any settings on my AVR that might be key to look at in this case?
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #25 of 26 Old 12-12-2013, 11:05 AM
ousooner2's Avatar
Quoted: 291 Post(s)
Liked: 179
If you want 'full spectrum sound' then you either need a capable sub(s) or MUCH more expensive towers
Currently Auditioning: Klipsch RP-150M
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
post #26 of 26 Old 12-12-2013, 04:56 PM
Quoted: 255 Post(s)
Liked: 146
I hope you meant 1700cubic feet and not square feet. Lol
Square feet is going to be a lot to fill with two towers and expecting to feel any bass output.
Anyway, maybe something weird in the receiver? Can you reset it?
All my setup is to get full range is set to stereo for 2 channel listening and I set 2 channel to play my towers on large and full range frequencies.
No frills here. Simple settings.
Again I would put the jumpers back in and screw the bi wire. You are drawing more power away from the woofers by using two more channels for tweeters. Power goes down per channel when driving more channels.
Avrs rate wattage by 2 channel and then much less when all channels are driven. So that might be a major denominator in the equation.
Reply Speakers
Pioneer Sc 37 7 1 Channel 3d Ready A V Receiver , Klipsch Reference Series Rf 82
