Advantages of 7 speakers over 5? - Page 2 - AVS Forum
post #31 of 58 Old 10-14-2013, 07:06 AM
caloyzki's Avatar
Quoted: 27 Post(s)
Liked: 40
Originally Posted by Brad Sutliff View Post
I have A 7.2 setup. I don't have a big room however. So I have front highs. I love them. They made my small room sound twice as big. Some people don't notice the effects as much from highs but in my room I did. I'd go for that. With bookshelves. And then keep the 4 subs. I'm jealous
Can i see the pic of your 7.2 set up sir? Thanks
(2) Energy RC 70 towers
(1) Energy Veritas 2.0C center
(2) Energy Veritas 2.0R surrounds
(2) Energy RC LCR back surrounds
(1) Rythmik LV12R sub
(1) Denon 2112CI avr
(1) LG 55" LM7600 tv
caloyzki is online now
post #32 of 58 Old 10-14-2013, 07:18 AM
Brad Sutliff's Avatar
Ill try to get a photo of it later today.
caloyzki likes this.
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #33 of 58 Old 10-14-2013, 06:20 PM
caloyzki's Avatar
Quoted: 27 Post(s)
Liked: 40
Originally Posted by craig john View Post
The OP said something about film. It's obviously something he cares about. rolleyes.gif
Blee0120, there are lots of movies with content in the rear surrounds. Sometimes it is placed there for directionality and sometimes it is placed there to add spaciousness. In addition, for 5.1 movies, you can add PLIIx or DTS Neo processing to add the rear surrounds. They are definitely worth doing if your room and seating can support them. However, if your seating is against the rear wall, you can't get rear speakers "behind" you, in which case there is no benefit.
Craig
How about my surrounds on my set up :-)
post #34 of 58 Old 10-14-2013, 06:33 PM
Lol those are like bam! In your face
post #35 of 58 Old 10-14-2013, 06:44 PM
caloyzki's Avatar
Quoted: 27 Post(s)
Liked: 40
Hahaha. It really sounds good especially during movies!
post #36 of 58 Old 10-14-2013, 06:44 PM
Lol as long as their calibrated I'm sure they do!
post #37 of 58 Old 10-14-2013, 06:45 PM
psgcdn's Avatar
Liked: 186
How do you even calibrate levels for that? Moving a few inches is going to change it all. Do you sometimes hear the rear surrounds a lot louder than the front three?
psgcdn is offline
post #38 of 58 Old 10-14-2013, 06:46 PM
Lol you just have to sit still
post #39 of 58 Old 10-14-2013, 06:59 PM
caloyzki's Avatar
Quoted: 27 Post(s)
Liked: 40
Yes my 7.2 set up is calibrated by audyssey XT. I don't listen to music only movies 100%. So surround back not that big deal coz it's only mono during movies and i like the sounds
post #40 of 58 Old 10-14-2013, 07:43 PM
AVS Club Gold
craig john's Avatar
Quoted: 20 Post(s)
Liked: 273
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #41 of 58 Old 10-14-2013, 07:56 PM
caloyzki's Avatar
Quoted: 27 Post(s)
Liked: 40
Craig
post #42 of 58 Old 10-14-2013, 08:04 PM
lespurgeon's Avatar
Liked: 40
Originally Posted by blee0120 View Post
My room is 12ft wide by 16ft long, with 8ft tall ceilings. I have about a foot on each side of the screen. 15in at most. I have to measure after work. They would be in stands
That size of room you should be able to make 7.4 work, depending on layout and seating location - I assume not against the back wall.
lespurgeon is offline
post #43 of 58 Old 10-14-2013, 08:09 PM
here you go cayloyzki. Taken with my phone so bad quality. Two surrounds are directly to the side.
post #44 of 58 Old 10-14-2013, 08:11 PM
Caloyzki*
post #45 of 58 Old 10-14-2013, 08:37 PM
AVS Club Gold
craig john's Avatar
Quoted: 20 Post(s)
Liked: 273
I'm speechless.
Craig
Lombardi said it:
My System
post #46 of 58 Old 10-14-2013, 08:44 PM
jenkzy56's Avatar
I'm speechless.
Craig
What he said !!!
jenkzy56 is offline
post #47 of 58 Old 10-14-2013, 08:48 PM
Lmao why?
post #48 of 58 Old 10-15-2013, 12:32 AM
GIEGAR's Avatar
Quoted: 24 Post(s)
Liked: 334
Because if your surrounds are where I think they are Brad, they're about 70 degrees from the recommended position.
Sounds that the content creator intended as ambient diffuse soundfield around you and/or discrete directional effects beside and behind you will instead be coming from, or adjacent to the screen.
FWIW, your front height speakers look OK.
Edit: Fixed clunky grammar and removed a cheeky question.
GIEGAR is offline
post #49 of 58 Old 10-15-2013, 06:44 AM
AVS Club Gold
craig john's Avatar
Quoted: 20 Post(s)
Liked: 273
I can't tell if you're using surround bipole/dipole speakers as your front speakers, (which is a pretty bad idea), or if your surrounds are just very badly placed and aimed the wrong way. If the later, where are your front speakers?
One speaker stand is a box. The other speaker has a box on top of it.
The speakers we can see are mounted at different heights.
I don't know if it's just the camera angle, but your screen appears curved at the top and straight at the bottom.
Lombardi said it:
My System
post #50 of 58 Old 10-15-2013, 07:19 AM
Lol I'm in the middle of upgrading. So yes they're surrounds as fronts. Because I didn't want my fronts to be worse than my surrounds. There is no box on top of the speaker lol there's stuff behind it. Must be the angle. The screen is not curved I actually did.t notice that in the picture. I don't know why it is.
post #51 of 58 Old 10-15-2013, 07:22 AM
I can't believe you guys thought I'd place surrounds in the front! That's hilarious
post #52 of 58 Old 10-15-2013, 09:45 AM
GIEGAR's Avatar
Quoted: 24 Post(s)
Liked: 334
But you actually have! You're just not routing the surround audio channel through them. But we weren't to know that, because you're using the term "surrounds" interchangeably.
Go back and look at what you actually said, not what you know. Like here:
Which in conjunction with the pic, I took to mean: Two surrounds are directly to the side (of the display).
A quick explanation like you have now provided would've been handy.
GIEGAR is offline
post #53 of 58 Old 10-15-2013, 09:54 AM
AVS Club Gold
craig john's Avatar
Quoted: 20 Post(s)
Liked: 273
Craig
Lombardi said it:
My System
post #54 of 58 Old 10-15-2013, 09:59 AM
KidHorn's Avatar
Quoted: 59 Post(s)
Liked: 163
I have a 11.3 setup. Something happened to my receiver settings and it played everything in 5.x and it sounded awful. When I reset it back to 11.x, it sounded much better. Even my kids said it sounded a lot better and they don't care about anything. I never thought the extra ambiance of the height /wides/rear surrounds made much difference, but it does. My rears are about 10' behind the sofa.
KidHorn is offline
post #55 of 58 Old 10-15-2013, 10:03 AM
Well they sound better than what i had as fronts so thats all that matters. Its temporary. A broke college students gotta do what hes gotta do
post #56 of 58 Old 10-15-2013, 02:58 PM
AVS Club Gold
craig john's Avatar
Quoted: 20 Post(s)
Liked: 273
Have you considered moving the monopole Heights down to the Mains positions and moving the dipole/bipole "surrounds" up to the Heights positions?
Lombardi said it:
My System
post #57 of 58 Old 10-15-2013, 03:33 PM
I have but it would be difficult because of the way I'd have to unmount and mount the other speakers. And since it's temporary I've just decided to stick with the way it is. My setup is progressing slowly lol
post #58 of 58 Old 10-16-2013, 04:21 AM
FATHERFORD's Avatar
I just went from 5.1 to 7.1 and the difference was drastic. It added a new dimension in my setup.
Makes me wan to go to a 11.x now.
Brad Sutliff likes this.
FATHERFORD is offline
Reply Speakers
User Tag List
