Ground loop issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-13-2013, 10:12 AM - Thread Starter
shelly40's Avatar
Quoted: 141 Post(s)
Liked: 51
When my system is set at minimum volume, there is
hissing/buzzing sound coming from all of the tweeters
in my system....
This doesn't seem very good for the tweeters...
I'm thinking it is a ground loop problem...
So I try one of those "cheater plugs"..
It seems to have greatly diminished the noise coming
from the tweeters....
What are the downfalls of using the cheater plug ?
Can anything bad happen ?
Or is it fine to just keep using it ?
Shelly
shelly40 is offline
post #2 of 5 Old 10-13-2013, 10:23 AM
coytee's Avatar
Quoted: 161 Post(s)
Liked: 285
Try a grounding plug on the input of each channel.
Take a RCA line, cut/twist the ends together so the +/- are together.  Plug into the input and then listen.
My understanding is this process will negate everything and let you know what the base level noise of your unit is.
Are you using highly sensitive speakers?  Sounds like you might have (at least) a horn tweeter?
coytee is offline
post #3 of 5 Old 10-13-2013, 10:28 AM
losservatore's Avatar
Quoted: 2302 Post(s)
Liked: 2047
Check if this help
Before doing this unplug anything from that outlet and use a lamp to make sure that you are turning off the right outlet , go to the breaker panel and turn the breaker of that outlet off and then back on.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #4 of 5 Old 10-13-2013, 08:04 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
in my system....
Shelly
If you hear a buzz or hissing sound, it's probably not a ground loop, because a ground loop makes a "humming" sound. The buzz or hissing noise is probably RF noise. Keep your A/C lines separated away from your other cables behind the equipment rack. If they must touch each other, do so at a 90 degree angle.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is online now
post #5 of 5 Old 10-14-2013, 06:33 AM
Bill Fitzmaurice's Avatar
Liked: 4639
The cause of ground loops is unbalanced connections:
http://www.rane.com/note110.html
To find what's causing it start with nothing plugged into the AVR, then plug in components one at a time. Transformer isolation of the interconnect is one cure. The usual culprits are powered subs and the TV cable.
But ground loops cause low frequency hum, not high frequency noise. High frequency noise is usually caused by dimmers and flourescent lights.
Bill Fitzmaurice is offline
Reply Speakers
