Want to finally get rid of bose - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-14-2013, 07:22 AM - Thread Starter
Martin30's Avatar
I'm moving and the lady that bought my townhome asked if she could pay me to leave the bose acoustimas 10 IV. I was never happy with tje setup, it is my fault because haven't researched. My av is Hk 354, what are my other choices to go with i still want to be able to mount them on walls.
The bose lists for 999 at bestbuy is it fair to ask half for them? Their wired and hanging she just has to get an av receiver.
Martin30 is offline
post #2 of 8 Old 10-14-2013, 08:20 AM
Brad Sutliff's Avatar
What is your budget? And are you looking for a 5.1 system? how big is your room?
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #3 of 8 Old 10-14-2013, 08:38 PM - Thread Starter
Martin30's Avatar
I dont want to spend too much, say 1500 $ 5.1 is fine maybe 7.1 My room is 11 feet by 23 feet.
Martin30 is offline
post #4 of 8 Old 10-14-2013, 09:39 PM
23ft long? I would definitely go 7.1 atleast if it was me. Probably 7.2. But check out Bic acoustech, aperion audio, fluance. I'll try to find some stuff
post #5 of 8 Old 10-14-2013, 09:48 PM
Check out the aperion intimus 5b system. It's right at your budget. But you would still need a receiver? It's a 5.1package. You could go down to the 4b but with your size room I'd probably go for the larger drivers.
Another set up I'd look into is the bic acoustech. With two ht64 bookshelves and two pl66 surrounds. With the pl26 center channel. For the sub either the f12 or pl200.
post #6 of 8 Old 10-15-2013, 05:35 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Another good choice is HTD.
Level Three Bookshelves - $300 FL/FR
Level Three Center - $200 C
Level Two Bookshelves - $200 SLSR
SVS PB-1000 - $500 Sub
Denon AVR-1913 - $300 (www.accessories4less.com)
Comes to $1500 exactly and gives you a great system with a very good sub.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #7 of 8 Old 10-15-2013, 06:23 AM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
That's a biggish room, I'd consider 2xPB1000 or comparable subwoofers, and $500 worth of bookshelf speakers and a center channel.
ermghoti is offline
post #8 of 8 Old 10-15-2013, 06:27 AM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
Oops, you need a receiver? Go to NXG NX-BAS-500 for the subs, or BIC PL-200s if the NXs are unavailable.
ermghoti is offline
Reply Speakers
