Polk LSi25 question - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2013, 09:27 AM - Thread Starter
Msullivan's Avatar
Hello all I haven't really looked at Polk Speakersuntil now , but the LSI25 models caught my eye. I am planing a HT room in my basement 20X25 with 60% music 40 movies. I was wondering what your all opinon is of these. They look like an older model which is being closed out. any help with these would be great!!
thanks
Mike
Msullivan is offline
Old 10-14-2013, 09:54 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Good speakers, but have been replaced with a newer model, the lsim series. The matching center for the lsi series is really hard to find these days, just something to keep in mind if you are going to set up a full 5.1 or more theater system.
I don't need snobs to tell me how to think, thank you!
67jason is offline
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
thanks
Mike
Hey Mike, you're right, the LSi25 is a discontinued model but still a great speaker. Some would argue that the LSi15 would be better due to the power to drive them vs the sub you get with each one.
These are 4ohm speakers which means you'd need to have some power to drive them. I have RTiA9's 8ohm speakers, almost went with the ones you're considering.
Also, as you mention, 60% music, another thought is to go with the LSi9 and a sub.
If you shop the Polk Audio ebay link, you'll find decent deals often on these speakers.
http://stores.ebay.com/Polk-Audio-Direct/_i.html?rt=nc&_sid=686154689&_trksid=p4634.c0.m14.l1513&_pgn=1
You'll find a couple of pairs of LSi25's on there now.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Old 10-14-2013, 10:09 AM
XStanleyX's Avatar
Liked: 1269
There is a LSiC on ebay right now if you decide to go for the LSi's. There's a make offer button. If you make an offer be aware it is binding for 48 hours or until he accepts or rejects your offer.
http://www.ebay.com/itm/Polk-Audio-LSiC-Center-Speaker-/190921322750?pt=Speakers_Subwoofers&hash=item2c73cc30fe
I used to own the LSi15's. Nice speakers and very well built.
XStanleyX is offline
Old 10-14-2013, 02:34 PM - Thread Starter
Msullivan's Avatar
Thanks guys I appreciate your feed back. One question for you, for 1700.00 or so( what the lfc run) is there something else you would recommend other than the LSI's?
Old 10-14-2013, 02:43 PM
XStanleyX's Avatar
Liked: 1269
I would look at the used market on craigslist, audiogon and ebay and see what you can come up with. Haven't a clue where you're located for craigslist but it's always worth a look. $1,700 can usually get you some pretty good speakers. Possibly better than the LSi.
Old 10-14-2013, 07:32 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
kef Q series. check for them on accesories4less.com.
67jason is offline
Old 10-15-2013, 05:46 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
If you could stretch a little bit, the Ascend Sierra Towers are fantastic.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 10-15-2013, 11:13 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Hey Mike, for 60% music, you could look at the Polk LSiM 703 for starters, very musical. Otherwise, for that budget, you could walk away with a pair of RTiA9's and a CSiA6 (also Polk). These speakers are very capable for music and are great H.T. speakers.
Set up:
Old 10-16-2013, 09:30 AM - Thread Starter
Msullivan's Avatar
Hey guys another question for you. the LSI25 priced just dropped to 1000.00 a pair. Are these speakers worth that kind of money or is the newer technology better, and I should look somewhere else?
Old 10-16-2013, 09:33 AM
XStanleyX's Avatar
Liked: 1269
Very much worth the money. That's what I paid for a new pair of LSi15's on amazon. I assume that price is for a new pair.
Old 10-16-2013, 09:42 AM
XStanleyX's Avatar
Liked: 1269
Just saw they are on amazon. The seller is an authorized dealer so the Polk warranty is good. Not sure you can do better at that price.
Old 10-16-2013, 09:58 AM - Thread Starter
Msullivan's Avatar
Thanks!!! I wanted to make sure before I press the button :-)
With the built in sub woofers will I need to add another woofer down the road for movies?
Old 10-16-2013, 10:01 AM
XStanleyX's Avatar
Liked: 1269
Depends on how bass hungry you are. A powered sub will help with nearly all speakers. Especially for movies. Don't forget a center speaker. That one on ebay is a fair price. You can always make an offer.
Polk Audio Lsi25 Left Channel Tower Speaker Single Cherry
