Best speaker option - AVS Forum
post #1 of 8 Old 10-15-2013, 10:37 AM - Thread Starter
pmsmith2032's Avatar
I am looking for suggestions on which speakers to order. The speakers will be connected to a Denon 1613. The speakers would be primarily for home theater viewing (at least 75%). Initially I am just planning on ordering two bookshelf speakers with plans later to add a center, subwoofer and floorsting speakers (moving the bookshelf speakers to the back to act as surrounds). The room they will be in is large (12' by 30' in the section we are going to put them in with a total of approximately 600 total square feet with open doorways into another room approximately another 200 square feet). My choices are:
Audioengine P4
Boston Acoustics A25
Cambridge Audio S20
Infinity Primus P163
KEF C3
Klipsch RB-41II
Polk Audio RTiA1
Polk Audio TSi200
Polk Audio TSi100
Polk Audio TSx110B
Polk Audio TSx220B
PSB Alpha B1
PSB Alpha B4
Yamaha NS-BP400PN
I could also order any of the following floorstanding speakers:
Infinity Primus P253
Polk Audio TSi300
Yamaha NS-F150PN
I have "points" in my health program so none of the above would "cost" me anything. Thanks in advance!
pmsmith2032 is offline
post #2 of 8 Old 10-15-2013, 10:54 AM
Transmaniacon's Avatar
Quoted: 332 Post(s)
Liked: 380
I would go with the Infinity Primus P163, a lot of those speakers are more suited for satellite duty. Also, it will be easy to complete the system later on. Can you also get the P363? They would be a better option for 2.0, and then add some bookshelves, a center, and sub later on.
Living Room
Samsung PN60F5300 | Denon DBP-1611 | Roku 3
Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | BIC F-12
Computer
Topping TP23 | NHT SuperZero 2.0 | Velodyne DEQ-8R
Transmaniacon is offline
post #3 of 8 Old 10-15-2013, 11:02 AM - Thread Starter
Thanks for the response. Unfortunately I only have enough points for the P253 in towers (the P363 is twice as many).
post #4 of 8 Old 10-15-2013, 04:22 PM
bladerunner6's Avatar
Liked: 55
Audioengine P4
Cambridge Audio S20
KEF C3
Klipsch RB-41II
Polk Audio RTiA1
Polk Audio TSi200
Polk Audio TSi100
Polk Audio TSx110B
Polk Audio TSx220B
PSB Alpha B1
PSB Alpha B4
Yamaha NS-BP400PN
Polk Audio TSi300
Yamaha NS-F150PN
For a room that size, some towers would be your best bet and the P253 would be my choice.
bladerunner6 is offline
post #5 of 8 Old 10-15-2013, 04:41 PM
Brad Sutliff's Avatar
Points? Lol how are you getting these??
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #6 of 8 Old 10-15-2013, 06:35 PM
iamwardicus's Avatar
I'd suggest getting the P163 for free, and if you live by a frys electronics, they tend to get the 363 towers for $99 or $109 each on sale every 3-6 weeks I think. save up later for the matching center as it's usually expensive...
iamwardicus is offline
post #7 of 8 Old 10-16-2013, 05:38 AM - Thread Starter
Thanks. I've narrowed it down to the Infinity P163 and the Polk TSi100 (based on advice from others). Any benifits between the two? The points, by the way, are awarded through my employer for reaching certain health-related goals.
post #8 of 8 Old 10-16-2013, 06:38 AM
The only other thing I can add is if the speakers are going to be close to a wall you'll want the front ported P163 as it won't be affected by boundries around the speaker as much as the Polk. The P163 should be able to play lower frequencies a little better than the Polk since it's using a larger driver and is physically a larger speaker. Both speakers have budget options for adding more speakers to go 5.1 if you ever desire (Frys for the Infinities, Polk sales on newegg or their ebay store for them).
Aside from that either speaker will do the job you intend it to do - and later on you'll suffer from upgraditus and want more or better speakers so it'll be a moot point by then wink.gif Good Luck cool.gif
EDIT: On a slightly different note, if you don't ever plan on expanding beyond the 2.1 system, get yourself the floorstanding speakers. The Yamaha is probably a little better than the infinity, but I can't comment as I've never heard a yamaha speaker. The placement issue with front vs rear port is the same between the two. I'll still recommend the Infinity since I've experience with the brand; I've heard polk before (in the store admittedly, never home auditioned them as I just didn't care for them).
Reply Speakers
User Tag List
