Bose Jewel Cube speakers as surrounds on a Denon receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-15-2013, 01:20 PM - Thread Starter
Snick2040's Avatar
Ive upgraded my system to a pair of Dynaudio Focus 160 and a center 210 C running off a Denon x4000 (will be getting a 3 channel amp soon). I would like to hook up my old Jewel Cube speakers for the surround and rear channels.
It been difficult to get information on whether this is doable. The sales guy at bose said go for it. While, tech support at Bose said no trade it in for an upgrade. I know the Jewel Cube's need to be hooked up to the acoustimass module for proper crossover. But I was wondering if that was really important for the front main channels and since I wanted to run them as surround and rears maybe it was doable.
I have the adapters to hook up the bose speakers to regular speaker wire. I even spoken to the guy who sold me the Dynaudio and he said it was fine to hook them up. The Dynaudio's are 4 ohm while Ive read the Jewel Cubes could be anywhere from 2-8 ohms...
Snick2040 is offline
post #2 of 6 Old 10-15-2013, 06:10 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You can try it, I'm curious to see what Audyssey sets the crossover to for the Bose cubes. It'll probably be 150-200hz or higher.
Afro GT
afrogt is offline
post #3 of 6 Old 10-16-2013, 07:58 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
Those Bose speakers can't play below 200 Hz, so I doubt you'll be happy with this setup. There is a lot of full-range content on the surround channels in modern film mixes, so tiny surround speakers aren't really sufficient if you want the best performance from your system.
tsaville is offline
post #4 of 6 Old 09-28-2015, 12:05 AM
vamose's Avatar
Please help me with right selection. I am sold on the Bose, details below, but have a clear understanding form the AVS forum that Bose is no go.
Kindly suggest something, that will outperform Bose interns of size and performance.
Price point similar.
Requirement is to enjoy surround sound as well as good music. Music varies form Jazz, rock to pop. In short need an all rounder.
I have got a Subfwoofer, Parts Express - Dayton Audio SPA1000 1000W Subwoofer Plate Amplifier & Dayton Audio TIT400C-4 15" Titanic Mk III Subwoofer 4 Ohm. All though I cannot make it sound right. I have used regular wood enclosure, with no inside lining. If there is something you can recommend please feel free.
Bose JewelCube
Lifestyle® SoundTouch® 535 entertainment system
http://www.bose.hk/?content=1&catego...product_id=303
vamose is offline
post #5 of 6 Old 09-28-2015, 01:26 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Monitor Audio Radius 90
fatbottom is offline
post #6 of 6 Old 09-28-2015, 01:55 AM
fatbottom's Avatar
Liked: 518
This has got to be a joke. You have £1800 front speakers and £800 center and want to use crappy, low quality tiny little Bose satellites as side and rears?
I can understand if you don't want to spend £1800 on rears, £1800 on sides, so just go down the Dynaudio line, or get another brand that is affordable
I use four of these as side surrounds, the second pair cost £90. Tons better than Bose crap
Reply Speakers
Bose Premium Jewel Cube Speakers
