Paradigm Monitor 11 v7 or Focal Chorus 826V - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-15-2013, 07:18 PM - Thread Starter
mvettor's Avatar
Hi All!
What a dilemma! Which pair would you advice me to get? I will be using a Marantz AV 8801 in my living room (25 square meters). Any thoughts, pros, cons?
mvettor is offline
post #2 of 7 Old 10-15-2013, 07:23 PM
jm86wvu's Avatar
The AV8801 is just a pre-amp/processor. You're going to need an amplifier as well...
jm86wvu is offline
post #3 of 7 Old 10-15-2013, 07:31 PM - Thread Starter
mvettor's Avatar
You're right. That would be my old Marantz 3300 pre.
mvettor is offline
post #4 of 7 Old 10-15-2013, 07:51 PM
grasshoppers's Avatar
Quoted: 861 Post(s)
Liked: 562
Color me confused, but isn't this also a pre-amp??
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #5 of 7 Old 10-16-2013, 06:34 PM - Thread Starter
mvettor's Avatar
I am running a pair of hand made speakers (12"bass + 8" mid + super tweeter) directly from the Marantz 3300 so I thought I could run these new speakers though the AV8801...as you can see, I am a bit of a fresher on this, so any advice for amplifiers is also welcome.
mvettor is offline
post #6 of 7 Old 10-16-2013, 09:44 PM
Quoted: 861 Post(s)
Liked: 562
From what I have read the Marantz doesn't have any power
Amps, I could be wrong though, wouldn't be the first time.
Where are you located....makes a difference as to what is available
To you.
Are you going to use just two speakers or are you going to add more??
I am partial to Paradigm speakers...I owned a pair of the Monitor 11v5
Great speakers.
Rythmik F12 subs
post #7 of 7 Old 10-17-2013, 06:26 PM
darkpoet25's Avatar
Liked: 40
If you go with a Marantz amplifier, they have the MM8077 which is 150x7, the MM7055 which is 140x5, and the MM7025 a 2-channel amp. Are you going with a full speaker set up of either the Focal or the Paradigm?
Cliff
darkpoet25 is offline
Reply Speakers
Focal Chorus 836 V , Marantz Av8801
